'94 AC Install in a '95 D90 - Defender Source
Old April 9th, 2013, 10:17 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Retrofitting a '94 AC (Davia) system in to a '95 D90. I have the complete '94 harness and the '95 has the two plugs in the right footwell. Can I just retrofit the '94 harness to adapt to the '95 plugs?
I have the '95 AC wiring diagram and am looking for the '94 diagram. Anyone have it?
Semper Fi!
Old April 9th, 2013, 10:44 AM
I think Jason - leastonce had a whole thread on this for his '95 just last year.
There are manuals all over the web. I use these:
http://lhsw.com/d90/
http://www.internet-tools.co.uk/land...l%20(1993).pdf
Old April 9th, 2013, 10:51 AM
'94 is same as '93 for the AC ... i didnt have the plugs to make the change but you probably can do this by extending the 94 harness a little. The plugs run direct to the ECU and one of them tells the ECU that the AC is running to help with the idle ... I don't recall the others function.
I don's have access to my truck until Friday to look but will take a look back at my thread when Josh links to it ....
Old April 9th, 2013, 10:57 AM
Wolf Fabrication
Sterling Archer
'08 D3
Cool, I'll wait for Josh.
Semper Fi!
Old April 9th, 2013, 10:58 AM
AC24 is the connector ... the wiring is on page 46 ( ECU side ) and 47 AC side in this doc
on the 47 side you have to work out what wires on the '94 AC harness are equivalent. Given that 2 are ground and one is a signal when the AC is on ... it shouldn't be too tricky to figure out.
Old April 9th, 2013, 11:08 AM
Found it:
wwwdefendersource,com/forum/showthread.pho?t=44560
Old April 9th, 2013, 11:16 AM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by rijosho View Post
Classy
Semper Fi!
Old April 9th, 2013, 12:16 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
i am still laughing!
Old April 9th, 2013, 08:26 PM
Wolf Fabrication
Sterling Archer
'08 D3
Damn it...
I am looking for a clear, concise '94 AC wiring diagram. Similar to the '95 diagram below. I am trying to mate the '94 system to the '95 footwell plugs.
Also looking to see what wires go where on the '95 switches. Anyone? Beuler?
Name:	jan 23 12' 004.jpg
Semper Fi!
Old April 12th, 2013, 08:33 PM
the two long yellow go on the big double blade connector temp switch near the thermostat.
the front fan should be a single hot wire and a ground that you attach in the proximity.
the wiring in mine was rushed and i never got round to fixing it up ... but ,,, hopefully this will help. The yellow wire is the trigger to the ECU to tell it the ac is running and only gets power when all the triany ( system pressure ) , temp switch and ac clutch are engaged.
The black went to ground ... probably should be on the ecu via one of the leads but for this purpose any ground worked.
The black and white went to black from under the dash
now caution it was dark when i took the photo and was wearing a suit so didn't get too close. If something doesn't seem right let me know and i'll try and do better pics in the morning.
ID:	70016   Click image for larger version
Old April 13th, 2013, 03:34 PM
Jonathan - Does your AC back look like this?
If it does could you measure the port sizes? Thread? type ... nut sizes? anything in fact so i can get a matching sanden back?
thanks
also other useful docs for future people looking at this thread
http://p38arover.com/rover/p38a/Engi...UX_Systems.pdf
has the details of the wires to the ECU to help map out the connectors.
90, 95, ac, d90
WTB 94 or 95 D90 jefhuf Wanted 16 May 23rd, 2010 03:48 PM
95 D90 Sw TwisteD90 For Sale - Vehicles 5 November 20th, 2008 11:10 AM
95 d90 ebay ron Misc. Chit-Chat 0 March 25th, 2004 01:01 PM
'95 Yellow D90 ST w/ 3 tops dalesmith71 For Sale - Vehicles 10 March 19th, 2004 09:59 AM
removing AC from a D90 naeirie Defender Technical Discussions 10 October 13th, 2003 08:21 AM
