94/95 Power Steering Pump Options - Defender Source
Old February 15th, 2016, 01:55 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Are there any options out there for 94/95 trucks with the Vbelt setup? Nearly every pump I find is at least $300. Meridian Rebuilds them starting at 285 plus the cost to ship it out to CA.
The current pump I got from Tillery has only lasted around 4 years. The OEM pump lasted 15 years and 150K miles.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old February 15th, 2016, 02:57 PM
carlosz's Avatar
carlosz
Carlos
I have always asked my self the same question and never come up with a real answer...
have you looked at "rock auto"?
otherwise used, or new from one of the many rover parts suppliers on the forum.
Old February 15th, 2016, 03:30 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
They are pretty solid typically---mine lasted nearly 20 years. I pulled one from an RRC in the pull your parts place for something like $20.
Old February 16th, 2016, 11:52 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I just had to call Meridian and order another box from them as the last one I got from them didn't even last a year. They have a year warranty, but the second steering box they are giving me doesn't have a warranty.
I've heard great things from them but this was by far the worst steering box i've ever had. I went through 4 gallons of fluid in a weekend.
http://bit.ly/1WpHWdU
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 16th, 2016, 12:22 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
Which makes me hesitant on sending out my Steering Pump. I'd think for $300 bones there should be a better option. My second pump was one I got from Tillery. I ordered it in 2012 for $300 and it whines like a cat in a washing machine. Its probably a britpart.
I know you can convert the serpentine belts to a GM pump. At least if it goes its a much cheaper replacement.
1995 Defender ST
1996 Discovery SE7
Old February 16th, 2016, 12:37 PM
robertf
Robert F
1995 Discovery
does the v belt pump pulley have the same bore diameter and 3 bolt pattern as the serpentine pulley?
Power Steering Pump dimcon Defender Technical Discussions 11 April 9th, 2007 08:34 PM
95 d 90 power steering pump Needed Scott 9835 Wanted 2 November 28th, 2006 12:56 AM
Power steering pump johnnyg15 Wanted 0 August 16th, 2006 05:32 PM
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
