94/95 - 97 Swivel pin - Defender Source
Old October 30th, 2010, 01:27 AM
Jase
Jase
pending
Quick question for those who have 94-95 and 97 knowledge.
Are the upper swivel pin bearings and dimension of the pin the same on a 97 and 94-95 Defender. Rather then plug the rough-road sensor holes in an ABS axle, can I install a 94-95 swivel pin and call it complete? Any gotcha's?
Thanks in advance for any guidance,
Jase
Old March 29th, 2011, 10:42 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Mine are in need of replacement and since I no longer have the sensors either, and since the price difference between the two pins is huge, (1994-95 vs. 1997) I wanted to know myself.... so I drug out the LR parts manual and stated comparing components.
Though the external housings (swivel) part# is the same, (FTC3311 & FTC3310) up to 1997 VIN # VA105501, the swivel ball itself on the '94-'95 (FRC7065) is different than the swivel ball on the 1997 up to VIN #VA105501 (FRC2644).
The swivel ball in the '97 must have a larger upper pin hole to accommodate the large pin required to house the speed (anti-knock) sensor.
I do see that the swivel ball for the '97 (FRC2644) is the same for the 110, but the external swivel pin housings are way different.
For 1997 D90's with VIN #'s from VA105502, the external swivel housings have yet different part numbers (FTC5299 and FTC5298).
PS. The pin bearing and race set are the same LR #606666 for all.
The Timken part number are: Bearing 11590 Race 11520
Dennis
Swivel Pin bearings and preload D90user Defender Technical Discussions 7 May 31st, 2015 04:18 PM
Part ID ? Under lower swivel pin 16kpsi Defender Technical Discussions 8 May 12th, 2010 12:44 PM
Swivel pin shims KevinNY Defender Technical Discussions 23 July 17th, 2007 06:31 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
