93'D110 wont start has code #20 - Defender Source
Old January 12th, 2010, 08:05 PM
MRROVER
AL RUSSELL
97' D-90
does any one know what a code #20 is ? How do I fix it? please help
Old January 12th, 2010, 08:14 PM
http://www.robisonservice.com/servic...er_trouble.asp
I don't think there is a code 20?
Search "no start" or similar and you will see me explain how to go about trouble shooting a no start.
Old January 12th, 2010, 10:00 PM
MRROVER
AL RUSSELL
97' D-90
d-110 wont start
when I turn key on I hear fuel pump ticking and it turns over but it wont start. Some times it starts and runs fine Help!!!!
Old January 13th, 2010, 10:55 AM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Yes, there is a code #20, but I don't have a definition for it. I've seen it before but just cold-booted the ECU and it went away. (I have moved my read out box to the transmission hump so when a fault is displayed I don't have to go digging around under the dash.)
Search ["fault code 20" rover] and you'll see some threads. My guess is either MAF or stepper motor -- either could explain your starting issues...
DW
Old January 13th, 2010, 11:54 AM
I vote for ignition amplifier.
Old January 14th, 2010, 08:35 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I've been doing some digging myself looking for this code, no luck yet here either. If you guys find it, pass it on to me please.
I don't see it being the ignition module though, as the ignition is a stand-alone system and is only connected to the ECU by the tach feed.
-Hans
My oil line fix
My 100k stopped odometer fix
110, d110, start
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
