'93 NAS D110 Brake Light ON - Defender Source
Old May 21st, 2008, 11:03 AM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
I am getting the brake light on the dashboard to flicker on and off at various times while driving. This is the same light on the dash that comes on when the e-brake is engaged. It seems to come on more when braking then may flicker off and on a while after that.
It started after my first wheeling trip where I got a little muddy.
Serches here show posts about rear brake lights staying on but i didn't see any about the dash light staying on.
Is there a switch or something in/under the ebrake boot that could be bad? Or maybe just dirty?
Sorry - FSM is ordered and on its way here.
AndrewT
'93 NAS D110 #437
Old May 21st, 2008, 11:20 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Andy, when you figure it out, let me know, I have the same issue. I believe its the ebrake cable needing adjustment, because if i push the ebrake down all the way, it goes away.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old May 21st, 2008, 11:39 AM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
UpdateWill do Ryan. I was thinking maybe mud got jammed up in the ebrake housing and causing the drums to not fully reset once the cable is released. Or its a switch which is going bad. I have the ebrake cable fully released and the dash light still flickers.
I was buried in Pines Barren mud and basically high-centered on the mud. I could see how mud would have gotten in there when I was winched out. May need to crawl under there and check. But the ebrake is not engaging when the light goes on - the truck still rolls easily though that does not necessarily mean that the drums aren't fully releasing. Something tells me that the light is not sensing the cable or drum - but rather just a switch on the ebrake handle that determines position and lights.
AndrewT
'93 NAS D110 #437
Old May 21st, 2008, 03:56 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
That warning light is also tied into the brake fluid level sensor in the cap on the brake master cylinder. Check that as well, it might be cruddy or half plugged in or something.
Email:
Old May 21st, 2008, 05:40 PM
Or low on fluid because your pads are worn . . . .
Old June 21st, 2008, 02:50 PM
Lesandjes's Avatar
Lesandjes
AndrewT
'93 NAS D110
It was the brake light switch - the one down on the e-brake. Took 5 mins of time total now no more flickering brake light on the dash.
AndrewT
'93 NAS D110 #437
110, brake, d110, ht, nas
converting NAS '93 D110 or '07 D110 cosmetic specs rrcowner Defender Technical Discussions 2 March 5th, 2009 07:20 PM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
