93' nas 110 oil service info please? - Defender Source
Old February 20th, 2010, 07:29 PM
MRROVER
AL RUSSELL
97' D-90
I want to change my oil in my nas 110, trans and diff does anyone know which oil and how much to use? do they have a chart for a 93' Nas 110?
Old February 20th, 2010, 10:07 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I've been using Shell Rotella 15w40 for the engine, and you really need to keep up with the oil changes in the 3.9's in order to prevent a nasty sludge problem. For a filter, go with a NAPA Gold, WIX or Amsoil. You can use a larger size than stock also, I just forget the part numbers. Cross-Reference those brands with a Fram PH8A for the larger one(just don't actually USE that Fram, it's a terrible filter.)
Transmission calls for ATF.... even though it's a manual transmission.
Transfer case, steering knuckles and differentials I've been using 80/90 gear oil.
This is all off the top of my head, while at work.... so if anybody see's incorrect info here, please correct me.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 21st, 2010, 12:57 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I like to use synthetic (amsoil) ATF in the transmission, Some guys like the Reline, Royal Purple is great too..
Keith
Big, Red and ... aaa Red..
Old February 21st, 2010, 09:21 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
This is what I know from owning a NAS D110 since 1998, and per the original manual, and experience.
This combination of oil brand and weight are best for sub freezing and 100+ temps.
engine:
5W-50 Castrol Syntec, pour 6 quarts in the engine and 1/2 quart in the oil filter just before attaching
oil filter is the larger Mobile M1-301
change both every 3,500 miles or 8 months
Transfer case, Differentials:
75-90 weight, I use a company that puts moly in the oil it is made by Schaeffer
drain and pour in till it runs out the fill hole
total for both diffs and transfer case about 7 quarts so you have enough to run out the drain
change every two years or 25,000 miles
Swivel Balls:
I use the one shot genuine LR tubes, but every two years I have to add a little, so I drain what I can, then fill.
Transmission:
If you have the LT77 (reverse is up and to the left) use any cheap ATF type F from the auto parts store and change every year. about 3 quarts with enough to run out the top just as the diffs and transfer box
I know there is much debate about the ATF, but trust me, if you live where it is cold you will have a tough time shifting using anything else.
Do not forget to grease the zerts with a grease gun. I think there are 6 locations on the drive shafts...
Best buy this from Rovers North too: CD ROM Tech Manual LHP28
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old February 21st, 2010, 11:34 AM
Hans's Avatar
Hans
Hans Haase
Out of curiosity, what kind of oil pressures do you see with the 5w-50? I've been considering going synthetic, but have too much of a loss rate right now. IIRC I'm loosing about a half quart per thousand miles.
-Hans
My oil line fix
Old February 21st, 2010, 11:50 AM
Jon_Winningham
Sterling M Archer
-Hans
just over 30 when driving, and just over 15 when stopped at idle
and no 3.9 tapping sound at idle either
no oil pressure light!
loving the 5w-50
my E46 M3 ran on 0w-60!
110, nas, nas 110, service
FS Parts Leftover from NAS 110 Build surf110 For Sale - Parts 32 March 2nd, 2010 11:24 PM
NAS 110 Safety Devices cage "parts" FS ECR The Vendors Loft 2 December 3rd, 2009 09:58 AM
converting NAS '93 D110 or '07 D110 cosmetic specs rrcowner Defender Technical Discussions 2 March 5th, 2009 07:20 PM
93 NAS D-110 Diff oil and Hub Seal Questions AHollander Defender Technical Discussions 16 October 23rd, 2007 02:46 AM
