91 RRClassic intermittent stall-TPS issue? - Defender Source
Old December 28th, 2008, 09:30 PM
Hi all. Sorry for the RR-related post. D-web is unhappy for the moment. Mods remove or move this if you see fit to do so, no worries:
RRC with stock 3.9 on acceleration have had the engine just cut right out. Not sure if it is really stalling as it picks right back up again after a split second without use of the key. More like a BIG hiccup. Then it throws a code 19 indicating MAF or TPS. Test of those per the manual and all looks okay except for the TPS which has a "dead spot" about the same place in the pedal travel as this occasional problem. The voltage swings up until the pedal hits this spot and then it drops to zero and begins climbing again. I figure this is the problem but thought I would share and see if anyone has any related experience or wisdom to share before I shell out the $$$ for a new TPS- or the $ for a good used one
Ren
Old December 28th, 2008, 10:28 PM
Crazy Rays trip ? I need to go this week.
Old December 28th, 2008, 10:56 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I'd replace the TPS (don't bother cleaning it, it seldom works) as well as go through the ignition diagnostic procedure in the workshop manual. Might also want to check your vacuum lines, one of my rrc's had a nasty occasional stumble due to a very slightly cracked vacuum advance tube. I may still have a spare tps in the shop, I'll look for you tomorrow.
Old December 28th, 2008, 11:25 PM
Sounds like TPS to me.
Old December 29th, 2008, 09:03 AM
thanks tony. let me know. need to come by your place anyway and look @ the LWB for a friend.
Doug, can't justify the time off this week, though hoping I have a reason to call in sick on Friday...
Old December 29th, 2008, 09:31 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Vultures are circling, best hurry.
Old December 29th, 2008, 12:20 PM
SOUTHPAW26
Kelly
1994 D90-1993 NAS 110#280
I had a similar problem in my 1991 RRC. I replaced all the ignition components and it fixed it. I almost did not replace the cap as it looked brand new. But upon farther inspection it had carbon traces inside the cap. I also replaced the rotor button as I have had many problems with them in the past.
classic
OPen loop stall, or at least I think it is open loop! Neo Defender Technical Discussions 18 January 25th, 2012 11:34 AM
Intermittent wiper issue Craigd Defender Technical Discussions 2 January 8th, 2008 02:53 PM
Random & Intermittent Fuel? Problem popeohana Defender Technical Discussions 2 July 18th, 2005 02:47 AM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
