90 v8 clutch problem - Defender Source
Old August 19th, 2004, 06:45 PM
robheath
robert heath
Unhappy 90 v8 clutch problem
i have a land rover 90 3.5 v8 on which i have just replaced the clutch with a new 3 piece kit due to a faulty thrust/release bearing, (it was screaming like a banshee and was making a very loud grinding noise), once i had got the clutch out it didnt apear that bad just a bit scorched, but about 4 days later it has started making the grinding noise again no where near as loud but still loud enough to be normal!, its not screaming either i have done 60 miles on the new clutch and i changed and bled the fluid in the clutch when i did the job too
any ideas!!!!!!!!!!
cheers rob heath
90, clutch, v8
clutch problem diagnosis help... bharris Defender Technical Discussions 18 November 14th, 2011 04:42 PM
odd clutch problem tomaco1 Defender Technical Discussions 1 November 29th, 2009 07:20 PM
is there a clutch pedal adjustment for 95 d 90? rickauf Defender Technical Discussions 6 May 21st, 2008 02:56 PM
Clutch problem Capt Milks Defender Technical Discussions 0 February 11th, 2007 09:49 AM
