90 ST Cage Removal - Defender Source
Old August 6th, 2009, 01:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
90 ST Cage Removal
At some point I want to have my 90's cage powder coated. It looks like it comes apart easy (at least easier than the 110) My question is, can you remove the cage above the doors? I know there is a bolt there to pull most of the cage away but what if you want to remove that last piece that goes into the supports behind the doors?
Old August 6th, 2009, 01:51 PM
The whole thing just comes off with the bolts. Big tip is to spin the nut while holding the torx bit, rather than spin the torx bit. Less chance of stripping. This obviously does not work on those bolts without nuts on the other end. You cannot remove the part that goes into the foam bit on the b-pillar.
Old August 6th, 2009, 01:54 PM
bjf's Avatar
bjf
barry f
94 ST #395
wait I put the wrong pic up
So no one recoats that part?
Old August 6th, 2009, 02:15 PM
Not sure how you could do it. Maybe mask off the foam part? On a 1994, the outside foam ring is removable so you could do a proper mask job, but I am guessing the process would hurt the foam.
BTW there is nothing wrong with that cage as it looks now.
Old August 6th, 2009, 02:18 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ha, I am not doing anything to that cage for a long time but I am trying to learn.
Old August 6th, 2009, 02:19 PM
Why are there no snaps on your doors?
Old August 6th, 2009, 02:29 PM
phoenix37's Avatar
phoenix37
john
More importantly why do you run a top at all?
Old August 6th, 2009, 02:31 PM
bjf's Avatar
bjf
barry f
94 ST #395
I assume my doors are not original. The guy I bought the truck from never did any work to it either in the 6 years he had it, but I am assuming some one did some paint work before him. My soft top rails are body color but the rivets are not painted. If I take the windows off the doors, the rivets in the top are not painted either. It was done well that is for sure.
Old August 6th, 2009, 03:35 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
As for the soft top rails, the rails are an after market item on 94's. 94's came with snaps for the soft tops.
Weldon
Old August 6th, 2009, 04:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
I know about the snaps but most people with rails only have black ones. Just pointing out some paint work had to be done
90, cage
Defender 90 full Exo Cage NashvilleRover Defender Technical Discussions 19 July 24th, 2009 04:52 PM
NAS Defender 90 Roll Cage FORSALE RoverWrecks For Sale - Parts 2 April 8th, 2009 11:11 PM
ST Roll cage and soft top D90user For Sale - Parts 8 February 14th, 2006 01:23 PM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
Roll Cage Wanted for my 95 Defender 90 edducati Wanted 6 July 28th, 2004 03:34 AM
