90 Rear Drum to Disc Swap - Defender Source
Old April 27th, 2016, 12:32 PM
TigerDan's Avatar
TigerDan
Dan
1991 RRC
I'm about to do a rear drum-to-disc swap on an '83 90, I have a DI rear axle I'll swap in complete which will also give me 10-to-24 spline conversion as well as sway bar mounts (going to swap in the front as well.)
This 90 has a brake bias valve located on the right frame rail just forward of the bulkhead. I'm presuming I'll need to replace it, but I'm not sure. I've seen a lot of info saying replace it with one from a DI, or with one from a non-ABS RRC, or just leave it, or eliminate it. I was looking at the NTC8836 s a possibility.
Also wondering if I need to change the master cylinder. Looking at RovahFarm's site I don't a different one listed for disc or drum so I'm thinking not...
1991 RRC 4.2, R380, LT230, TrueTrac, Detroit, sliders, 33s, blahblahblah....
1994 RRC LWB
1994 RRC SWB
1995 D90 project
1961 SII
Old April 27th, 2016, 12:35 PM
Same MC so no swap required.
drum to disc conversion non-sals. Abrooks Defender Technical Discussions 11 March 5th, 2017 11:03 PM
PDWA swap after disc brakes upgrade? jafir Defender Technical Discussions 4 June 8th, 2015 11:16 AM
2 rear disc rotors 110 200tdi and 300tdi rear brake defender 110 up to 1999 Ben01 For Sale - Parts 1 October 6th, 2013 08:08 PM
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
D-90 rear drum brake axle assembly TDI Guy For Sale - Parts 0 November 6th, 2003 04:59 PM
