90 frame mods? - Defender Source
Old August 18th, 2005, 02:46 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
90 frame mods?
Hi, I'm getting ready to galvanize my project 90 frame and am wondering if anyone has any sugestions for modifications to the frame that require welding that I should consider before dipping it? Thanks.
Old August 18th, 2005, 03:45 AM
I would make sure it has mounts for both an NAS style rear tank and a Euro style side tank, though I understand some of the euro tanks are drill to existing outriggers only rather than welding on the outriggers.
Old August 18th, 2005, 04:38 AM
headdamage's Avatar
headdamage
Andrew
Yep... It has the mounts for the side tank and I've found a source for a rear tank that will fit it. It is an exmilitary 90. It had no engine and trans so I'm fitting a 3.5 efi V8 and ZF from a 1987 RR, I've welded in the V8 mounts and test fitted the complete engine and ZF with prop shafts and axles and it all looks good that way.
Old August 18th, 2005, 09:01 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Rear winch maybe?
The only other thing I could think of is heim trailing arm mounts.
Old August 18th, 2005, 09:46 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Are you looking for a rear tank for it? You said you found a source, but I have a cool option I am about to put for sale. I can post it up if you are looking.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 18th, 2005, 11:55 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would weld on reinforcement plates on the side rails between the front and rear trail arms as well as 1/4" skid plate that you weld onto the rear trailing ears-to-frame rail as this is an area that gets beat to hell on the trail.
Old August 18th, 2005, 12:42 PM
Seriesman's Avatar
Seriesman
Michael Elliott
1997 D-90 Hardtop (#2369)
I would second Chris' comment--because the D-90 frame is only 14 guage thick it will be very susceptible to damage between the mounts for the radius arms and rear trailing arms. You could simply buy "frame sliders" after the fact, but since you have the ability to weld you should consider adding on 3/16 (or whatever you prefer) plate now to this area to reinforce it. At the same time you could follow through to the actual frame mounts for the radius/trailing arms, thus eliminating two major hang up points on each side.
Michael
Old August 18th, 2005, 02:03 PM
headdamage's Avatar
headdamage
Andrew
Thanks for the sugestions so far guys. I've been thinking of welding a strip along the bottom between the mounts though the Rockware frame slider/plate things look really good to and might do a better job than I can. On the suspension mods, I'm going to stick close to stock as this truck will be used as a daily driver as well as an off road fun toy, I don't think that I'll be running tires over 33" but never say never
90, mod
NAS 90 Frame Used SafariHP The Vendors Loft 0 October 26th, 2009 08:38 AM
Defender 90 Tub & Frame Wolf Fabrication Wanted 13 September 9th, 2009 10:47 AM
NAS 90 Frame Partial SafariHP The Vendors Loft 6 October 24th, 2008 07:19 AM
What's a good condition 90 frame w eng trans go for SafariHP For Sale - Parts 3 May 15th, 2008 03:43 PM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
