'88 D90 swaying at "high" speed and gas pedal sticking - Defender Source
Old March 8th, 2016, 12:58 AM
ITALY2AMERICA
Zachary Hoyt
88 D90 CSW
Hey there, just picked up my '88 D90 and I noticed two issues, one that needs addressing and one that may just be part of the defender experience. First, I notice that when I'm driving on a downhill grade at highway speeds, the truck starts swaying in a somewhat harmonic fashion, which pulls the steering left and right enough that it requires constant attention. It's not a jerk, but it seems like the truck just doesnt want to go straight. I should note that mine is on offset 25cm 265 65 16" wheels and is lifted 2", which may be a contributing factor.
The second issue is that after I have been driving at highway speeds, obviously floored the whole time, the accelerator pedal sticks in the fully floored position. Anyone experience a similar problem?
Thanks!
Old March 8th, 2016, 01:13 AM
RBBailey
RBBailey
1965 IIa
With the swaying, check everything from tire wear and balance, to play in the bearings, to play in the steering rod ball joints, to the steering dampener, to the steering box, to the steering linkage... Chances are it is a ball joint.
Project:
1965 IIa SWB
Old March 8th, 2016, 06:51 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Dude, be careful. Taking a 30 year vehicle you don't much about yet and putting it through the stress tests can be dangerous.
I'd suggest having someone help you check the bushings and alignment and all suspension components. I be willing to guess shocks and bushings are shot and the tires are old and dry rot.
Sticky accelerator could be gummed up dirty cable from years of neglect.
Old March 8th, 2016, 07:10 AM
ITALY2AMERICA
Zachary Hoyt
88 D90 CSW
much appreciated, but the bushings are in good shape, and the shocks and the tires are less than 1 year old.
Old March 8th, 2016, 07:24 AM
1of40's Avatar
1of40
1of40
Wow, all that play on perfectly good bushes, shocks and tires. Could be the chassis is toast or the crossmember was removed.
Old March 8th, 2016, 07:52 AM
Are the tires properly inflated? That's check #1. Are the wheel lug nuts tight? If the steering is vague, it's possibly the steering box, or the column shaft has some play in it.
Old March 8th, 2016, 08:39 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Tire pressures? Toe-in (or out)? Swivel pin pre-load/bushings/pins? Trailing arm frame bushings? The lift took away some caster, but there is so much else to check....you mention that the "bushings are in good shape", but which bushings? I think there are at least 16 excluding sway bar and individual shock bushings....Based on what parameter are they good?
------ Follow up post added March 8th, 2016 08:44 AM ------
With the engine off, disconnect the throttle cable at the engine, operate the actual throttle by hand and see if it sticks open, then try the pedal and see if the cable sticks. What engine has been installed in your '88 defender 90?
Email is
Same place, new dogs.
90, d90, gas
Help! 110 Rear End Swaying. Neil McCauley Misc. Chit-Chat 24 June 4th, 2008 03:45 AM
sticking seat tracks cdb Defender Technical Discussions 2 November 10th, 2007 05:19 PM
5th gear and Reverse sticking anthony Defender Technical Discussions 2 May 22nd, 2007 12:09 AM
Clutch Pedal Sticking whitelandy Defender Technical Discussions 8 October 8th, 2004 10:23 AM
Heater Cables Sticking mgrgpg Defender Technical Discussions 1 October 21st, 2003 03:37 AM
