88 110 AC - NAS style - Defender Source
Old August 14th, 2015, 10:52 PM
Brentflyfish's Avatar
Brentflyfish
Brent McDonald
1988 LHD 110 SW
Can someone tell me how the AC controls work on an 88 LHD with factory AC? I am pretty sure I have an issue but need some help diagnosing. When I use the selector lever to move air to come out the dash vents the air continues to blow out the defrost vents. It used to eventually switch to the dash vents but seemed to have amend of its own, switching between dash and defrost on its own. Now it just comes out of the defrost. Is there a motor or vacuum hose to activate the plenum doors? Does not appear to be cables
Thanks in advance!
Old August 15th, 2015, 03:46 AM
rivermike's Avatar
rivermike
Michael
2008 LHD Tdci 110 Keswick Green
Correct brent, there is a bunch of vacuum hoses behind the facia, remove and check for leaks.
For LHD Defender restorations and refurbishments
WEBSITE :
EMAIlL :
Current Inventory is listed in my STOCKLIST section
Worldwide shipping is our specialty
Old August 15th, 2015, 08:08 AM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
I assume that means I need to take out all the dash fascia - the part with the vent louvres in it? Is there any other way to get to the hoses? Anyone have diagrams or pictures that show how it should look?
Old August 15th, 2015, 06:17 PM
Brentflyfish
Brent McDonald
1988 LHD 110 SW
I assume my vacuum lines are bad and potentially a vacuum motor or two. Are these worth fixing or should I scrap the dash system and go for the newer style systems? Will I need to get this working in addition to adding the newer style to the truck?
Old August 15th, 2015, 06:44 PM
Tarheeld
Bill
1985 110
Usually, the lines rot away hence leaks left and right secondary to the motors being overrun and finally giving away. Lines aren't the toughest of the lot to replace. Quick connect fittings are you best friend...
110, ac, nas
NAS style LED Lights upgrade kit for Land Rover Defender 90 / 110 atlcruiser The Vendors Loft 4 October 4th, 2014 03:09 PM
Is the AC compressor on a 1994 style system the same as a 95 style system? evilfij Defender Technical Discussions 0 May 31st, 2010 06:20 PM
wheelwell washer bottle needed (NAS 110 style) Overlander Wanted 2 February 22nd, 2010 08:40 AM
Help Needed - NAS 110 New Style Door Sill Seals R. Kurk Defender Technical Discussions 14 December 12th, 2008 11:48 AM
NAS Style Roof Rack for D-90 Joe P Wanted 14 October 4th, 2005 12:56 PM
