88 110 3.5L wont idle - Page 2 - Defender Source
Old February 19th, 2016, 05:50 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Altititude? LV's at 2000' & this rig was presumably shipped from somewhere else with a different altitude. Could that be something effecting idle?
Old February 19th, 2016, 07:04 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Move to a Holly carb and things will be much more enjoyable.
Old February 19th, 2016, 08:26 PM
gunsanroses91
patrick donovan
97 discovery 300tdi
I will try that and see if it helps. Im just lost because it started up perfect, little bit of choke for maybe a min. I drove probably 20 miles to 3-4 places. No starting problems or idling problems. Then this morning couldnt get it to idle at all. I said screw it and drove to work 2 miles away anyways. Still wouldnt idle when i got there. choke all the way out, pedal to the floor for a little.
Originally from south africa but was in colorado for 6 months before I got. So i should just have somebody look over it and perhaps adjust it. Anybody in vegas?
Thank you guys for the help, much appreciated!
Old February 19th, 2016, 08:34 PM
cowboy
steven
Hmmm, some of your posts could be taken as your scenario is that you are trying to drive around with it choked or partially choked. Is that what you are saying?
Also, much of the populated part of Colorado would be quite a bit higher than 2000' feet, right?
And didn't the guy that sold the impressive clown painting collection recently move to Vegas to hang a shingle?
Old February 19th, 2016, 08:48 PM
gunsanroses91
patrick donovan
97 discovery 300tdi
I may have driven around the block with the choke partially on, but it was before i learned that was bad. also only once. Probably way above 2000 ft, is there a guide with pictures on how to adjust? I feel like im looking under a car for the first time looking at those carbs.
Not sure who you are talking about on the clown painter! hah
Old February 19th, 2016, 09:08 PM
cowboy
steven
Don't hah - the clown painting guy may well be your only decent LR indy tech in Vegas...
Old February 19th, 2016, 09:29 PM
cowboy
steven
Google Image Search using searchwords "SU carb" has some labeled diagrams of SU carbs similiar but not necessarily identical to the pic that you posted - a few of them show an idle adjustment screw of some sort...might help to make sense of the link that Dro posted...Good luck!
Old February 20th, 2016, 08:22 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
So this all sounds like my engine before carb tuning, plug replacement, timing adjustment, and distributor.
Ran fine sometimes, became less reliable over time. Then it would idle ok but not drive well. Then it would sound ok, and die the first time I came to idle after driving.
I think it just needs a good full tuneup. Do whatever you can do yourself, take it to a shop for the carbs and the rest. Use the next 12 months of well running carbs to learn how to do em, haha
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old February 20th, 2016, 09:34 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
It's been a long time since I have used SU's
But you say it runs fine one minute and not the next, I take you have checked for any air leaks, the diaphragm rubbers are good, and the carbs are clean inside?
Hope the pictures are of use. One thing there no used pumping the throttle as these do not have pumper jets, pumping upsets the idle air bleed.
ID:	142841   Click image for larger version
ID:	142843   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 20th, 2016, 11:36 AM
roverman2010
1985 LR 90 200Tdi
Some tips on su's
https://m.facebook.com/PracticalClas...72455786106044
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
110, idle
Idle Control Valve (idle stepper motor) fleabus For Sale - Parts 3 June 28th, 2009 12:13 AM
Yet another Truck Wont start... arbik Defender Technical Discussions 12 September 21st, 2006 03:51 AM
HELP - D90 wont start....going camping on Thurs TurkD90 Defender Technical Discussions 6 July 25th, 2006 09:49 AM
Wont run at temp Neo Defender Technical Discussions 12 February 24th, 2006 06:54 PM
new bfg wont balance mattdh Wanted 7 October 27th, 2003 12:25 PM
