'87 110 Stationwagon Roll cage question - Defender Source
Old October 8th, 2015, 11:48 AM
piazzmic
mike
not yet
Long time lurker on the forums thats getting close to actually pulling the trigger!
I am trying to make sure my wife is happy with the safety aspects of having a little one in the back of a 110. Do the stationwagons have roll cage type structure in the tops or is it more of a bolt on that I should get a rollcage for?
I like the way the external cages look so I am not against getting one but just trying to make sure everything is safe should the unfortunate happen.
I searched the forum but was having a bit of trouble... Thanks for the help!!
Old October 8th, 2015, 12:05 PM
There is no roll protection on an 87 110. It needs to be added via an internal or external cage. Lots of threads regarding this.
Old October 8th, 2015, 12:17 PM
jafir's Avatar
jafir
Jafir Elkurd
Does your 87 still have a roof that has external ribs?
Old October 8th, 2015, 12:38 PM
If it is an original 87 roof it should have external ribs.
Old October 8th, 2015, 01:07 PM
piazzmic
mike
not yet
It does have the ribs. My understanding is that makes the safety devices roll cages not fit.
Old October 8th, 2015, 01:15 PM
I'm told the ribs can be dimpled in with a piece of pipe and a SD cage will fit.
Old October 8th, 2015, 01:20 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Just FYI I had an internal cage fitted to a ROW 110 I owned years ago. I was real pleased. I personally like the natural lines of the 110 so that was my primary reason for going internal but the SD cage follows the roof line very nicely and did not feel cramped inside IMO.
Old October 8th, 2015, 01:38 PM
grnrvrs's Avatar
grnrvrs
Paul
88
It depends upon the particular cage. Some SD cages fit with the older externally ribbed roofs and others do not. I have an externally ribbed roof with a SD cage, where the A hoop is external and the B, C, & D hoops and bracing are internal ala CT.
1970 SIIA 88, Sold
Old October 8th, 2015, 02:33 PM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
Which D90 roll cage is it I often see installed on 110's?
This one
Old October 8th, 2015, 03:02 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Safety Devices 4 point cage is what you are thinking of. It's not a specific D90 cage, it bolts to the roof and to the frame through brackets under the wings, in front of the bulkhead.
Land Rover 110 One Ten Station Wagon 4 Point Bolt-in Roll Cage | Safety Devices – Experts In Automotive Safety Solutions
Old October 8th, 2015, 03:10 PM
jason1st
Jason Crandall
Land Rover 110 One Ten Station Wagon 4 Point Bolt-in Roll Cage | Safety Devices €“ Experts In Automotive Safety Solutions
The one you linked has no rear support. It seems more for looks. The ones I see on D90's have a rear support.
Old October 8th, 2015, 03:17 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
If you are referring to the NAS 90 cage, it's not manufactured any more.
You could go external / internal
Land Rover 110 One Ten Station Wagon Multi Point Bolt-in Roll Cage | Safety Devices – Experts In Automotive Safety Solutions
Old October 8th, 2015, 03:23 PM
jason1st
Jason Crandall
Yeah. That's the one I want.
If I can't have the NAS 90 cage I'd rather go with the full external SD cage.
Old October 8th, 2015, 03:51 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Rbl1387sss is essentially a NAS 90 hardtop cage and is available. It just doesn't work in a 110 SW.
Old October 8th, 2015, 03:58 PM
bjf's Avatar
bjf
barry f
94 ST #395
Last I checked it was still made
Land Rover Defender 90 300Tdi Station Wagon Multi Point Bolt-in Roll Cage | Safety Devices – Experts In Automotive Safety Solutions
Old October 8th, 2015, 04:24 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Sorry, I'm talking soft top cage, not HT that is no longer made, and, as noted the Rbl1387sss won't fit a 110.
Your best option is the RBL148 7SSS - External/internal 'half' roll cage
Old October 9th, 2015, 08:19 PM
piazzmic
mike
not yet
Thanks all!
Old October 9th, 2015, 10:26 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Mike, while you are making the wife happy, don't forget to get rock sliders for side impact protection.
110, cage
Another 1986 LHD Def 110 Stationwagon SAUDI spec. rivermike For Sale - Vehicles 10 November 28th, 2017 09:44 PM
1987 Defender 110 Stationwagon V8 LHD Tophat For Sale - Vehicles 9 December 10th, 2013 05:47 AM
1983 Land Rover 110 Stationwagon LHD restoration stobbie Truck Build-up's & Restores 3 November 11th, 2012 08:48 AM
original 1985 LHD 110 Stationwagon 3 drs. rivermike For Sale - Vehicles 0 September 7th, 2011 05:09 PM
1985 110 Stationwagon PUMA/ SVX looks rivermike For Sale - Vehicles 37 February 13th, 2011 04:10 PM
