'86 Defender 110 2.5L turbo diesel question - Defender Source
Old July 4th, 2016, 11:50 AM
RobertLa
Robert
none
Looking for some help diagnosing a defender 110 2.5L turbo diesel. I have owned it for about a year with no problems except some small oil leaks which I have regularly checked levels and also rebuilt the radiator becUse of some early overheating problems. Recently it started to have heavy white smoke and sputtering upon starting at idle and continue to do so once driving (at idle only). It has always white/black smoked at ignition but would typically go away shortly after. Important to note that this is the first summer it's spend in the Lousiana heat so I've had to be careful for it not to overheat and have gotten the red oil light flashing (in neutral only and idle) a couple times when it gets close to the solid area of the temp guage but have always promptly stopped and let it cool off. Thanks for any advice as I am not aware of anyone close by that I could take it to. (SW Louisiana is location).
Robert
Old July 4th, 2016, 06:23 PM
RobertLa
Robert
none
Here are a few pics if that helps
Old July 4th, 2016, 06:28 PM
RobertLa
Robert
none
Trying to get more pics up
Old July 4th, 2016, 06:30 PM
RobertLa
Robert
none
Last one
Old July 4th, 2016, 07:29 PM
How recently have you changed your fuel filter ?
Old July 4th, 2016, 07:40 PM
RobertLa
Robert
none
Thx for the reply Doug. I looked at the service records I received with truck and it looks like it was 5 months prior to purchase. I have ran 7-8 tanks of gas through it but don't know the mileage. If this would be one of the first trouble shooting options I can definitely do it.
Robert
Old July 4th, 2016, 08:08 PM
This is pretty hard to diagnose via the internet. To me it sounds like two different issues.
A clogged fuel filter would limit your top end or cause stumbling at higher RPMs and probably not an issue at idle.
Just a hunch..... I would drain the oil and see if you have coolant in it. Since you mentioned overheating I'm thinking perhaps you may have a head gasket issue.
The oil light flickering would indicate a failing oil pump or failing pressure sender. I would swap in a new sender to start with, they are cheap enough.
Old July 4th, 2016, 08:29 PM
RobertLa
Robert
none
Thanks for the reply. I just went and tried again so I could better describe. It takes close to 15 seconds to actually be able to let go of the key and shakes pretty bad until I give it gas then bellows white smoke through the increase in RPMs and only slacks off when I let go of the pedal and then once it gets close to idol it shakes severely until it kills itself. I also noticed a clacking noise as I gave it gas but not consistently.
Robert
Old July 4th, 2016, 08:42 PM
OK, that sounds like you may possible have water in your fuel and the filter. I would change it out and the oil pressure sender, both very inexpensive. Do you have a sedimenter in your fuel system?
Old July 4th, 2016, 08:54 PM
RobertLa
Robert
none
Here is a picture of what I believe to be the fuel filter and pump. Something I noticed when I climbed under just now is a 2' puddle of diesel on the ground directly below this picture
Old July 4th, 2016, 08:55 PM
RobertLa
Robert
none
Old July 5th, 2016, 08:12 AM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
Picture is not real clear but the black canister is your oil filter...the small white canister at the top of the bulkhead is your fuel filter. The pump directly above the oil filter (in the picture) is your injection pump...the fuel pump is further back and bolted directly to the engine block...follow the plumbing from the fuel filter, one hose goes to the fuel pump. The sedimenter (if you have one) is a clear bulb on the bottom of the fuel pump. Also, the fuel pump has a small priming lever. It does sound like water in the fuel or could possibly be a bad head gasket allowing coolant into the cylinders. It is possible to drain the fuel filter and remove the sedimenter to expel water but if you do not have experience performing this procedure it would be worth having a diesel mechanic do the procedure as bleeding the fuel system can be a real PIA if not done correctly.
Concerning the puddle of diesel...can you tell where the fuel is leaking from?
Old July 5th, 2016, 12:06 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Since you're leaking diesel at rest (engine off) you are possibly/ most likely getting air into the fuel system which will also limit your top end performance AND cause excessive cranking to start.
110, defender, defender 110, diesel
19J turbo diesel oil change question awdbandito Defender Technical Discussions 4 March 7th, 2016 05:05 PM
Defender 90 110 130 Diesel Starter 200TDI 300TDI 2.5 N/A 2.5 Turbo rdavisinva For Sale - Parts 37 February 1st, 2016 03:01 PM
1989 Defender 110 County Station Wagon Turbo Diesel LHD in Spain Piero81 For Sale - Vehicles 7 January 9th, 2015 02:12 PM
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
RHD 2.5 Diesel turbo 110 CSW Defender globallandrovers The Vendors Loft 0 January 15th, 2008 06:06 AM
