86 D90 Brakes, Specs? - Defender Source
Old June 7th, 2004, 04:32 AM
Larns
George Larner
Guy's
Dose anyone know the spec's on british army 86 D90 braking system?
In particular I'm interested in weather it had a proportioning valve, an if it did
what was the cracking pressure of it.
I'm changing to four wheel disc and need to know if one's required(I'm starting
from a bare chassis and have no idea what was originaly on it).
Cheers Larns
Old June 7th, 2004, 07:13 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
you can just set it up like an NAS truck. you will need the valve, master cylinder and the brake pipes. along with the disc brake rear axle of cource.
Legend in My Own Mind.
Old June 8th, 2004, 06:28 AM
Larns
George Larner
Which valve are you talking about? If it's the proportioning valve then what model? there's quite a few different valves depending on cracking pressure requirements.
Cheers Larns
Old June 8th, 2004, 07:18 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I used MC #STC441 and valve #NTC8836. I then used all NAS brake pipes. they are all the same from 94-97
Old June 9th, 2004, 06:55 AM
Larns
George Larner
Cheers
I'll give those No's ago at the local dealer.
90, brake, d90
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
NAS D90 Specs JohnK Defender Technical Discussions 13 April 7th, 2005 12:05 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
