'85 d90 2.5NA starter brace - Defender Source
Old September 13th, 2013, 10:36 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
Do the 2.5NA diesels have a bracing bracket on the front end of the starter attached to the engine block or were they used on later TD or Tdi's? The d90 Green Bible, which covers the 2.5NA, TD and Tdi, shows and discusses a bracket but my truck has an original looking ground strap running from the forward bolt on the starter to the block where the bracket would be.
I am replacing my reluctant starter and will add the bracket if I should, seems to be a good idea on a diesel.
rgds, w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old September 13th, 2013, 11:40 AM
I've never seen one. Where is this in the manual?
Old September 13th, 2013, 12:11 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
It is in the 90/110 Workshop Manual, the Brooklands one, in the starter motor remove/replace and o/h section.
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old September 13th, 2013, 12:12 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You sure your not looking at the earth cable between the starter and the block?
But no brace that I have ever seen on NA's Td's or Tdi's
There is a heat shield fitted to Tdi's
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 13th, 2013, 12:26 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
No I have the earth cable where the WSM indicates there should be a secondary brace. May be for later engines since a few folks w/ NA's chimed in on another forum that they do not have them.
Apparently the bracket is relatively large $ also....I may not worry that much about it and consider it if I stumble across one at some point.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old September 13th, 2013, 02:25 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
someone dug up the details on another forum, part # etc4697...and it's not cheap
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old September 13th, 2013, 08:49 PM
edh
Ex mod 90
I have one that i removed from my ex-mod when i switched to a gear reduction starter if you're interested.Ed
Old September 16th, 2013, 07:36 PM
jafir's Avatar
jafir
Jafir Elkurd
Who makes or sells a gear reduction starter for the 2.5NA? I saw one at mean green, but it said it was only good up to 1980. And British Starters only lists for petrol engines on their site.
Old September 16th, 2013, 08:20 PM
Not sure the need. The stock starter works fine. I used to dead start mine at -40. Never had a problem with a starter.
Old September 16th, 2013, 10:12 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
I believe the OE Paris-Rhone/Valeo starters are geared, available....and pricey. Pretty sure some of the aftermarket ones are also, at least some of the ones I've seen advertised look like a more modern type geared starter.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
90, ac, d90, start, starter
2.5NA Starter Motor Issues Michael110 Defender Technical Discussions 3 February 24th, 2014 12:54 PM
d90 2.5NA starter brace for '85 d90 pitchrollyaw Wanted 0 September 13th, 2013 10:29 AM
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
