'85 90 Raising the seats - Defender Source
Old January 6th, 2015, 01:21 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
I'd like to raise my seats by ~1/4" or so to make accessing the underseat compartment a bit easier especially now that I have hardura down. I am looking for more clearance under the seat frame to remove the compartment lid.
I have the early 4 bolt per side seat rails and was thinking of simply putting spacers or washers under the mounting ears or using studs from the underside and nuts then sitting the seats on them, but was wondering if the seat mounting ears would take the load cantilevered between them for the long term. Seems like they should, it is only ~50lb per corner, but was wondering if anyone had done anything similar.
thanks.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old January 6th, 2015, 01:27 PM
Wayne,
Get a piece of 1/4" flat stock and make a square spacer with a hole in each corner. Problem solved.
Old January 6th, 2015, 01:33 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
Originally Posted by javelinadave View Post
Wayne,
Excellent point Javelina. Thought of that and have some...well enough to do one seat as a test, but i thought it would look like...well a sheet of square flat stock.... I will attempt how neat I can make the plates. Had the flat stock earmarked for my jump seatbelt backing plates.
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old January 6th, 2015, 01:34 PM
Match the corner radius and paint to match and I bet nobody even notices them.
Old January 6th, 2015, 01:48 PM
BRAB
Brandon
200TDI in a RHD 1986 D90
Made these a bit of overkill but did the job
ID:	110264   Click image for larger version
Old January 6th, 2015, 02:08 PM
A bit? Holy schnikeys!
Old January 6th, 2015, 07:16 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I just use washers as spacers. Seems to have worked for 10+ years now.
Old January 6th, 2015, 07:41 PM
What I do is run a bolt up from inside the seat box and put a washer and nut then the seat basically sits down on secure studs, and then another washer and nut. Result is the seat spaced up such that the seat box lids work easily. This is how the Tithonus trucks with the thick Wright Offroad sound matting were done.
Old January 6th, 2015, 09:06 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Originally Posted by pitchrollyaw View Post
I'd like to raise my seats by ~1/4" or so to make accessing the underseat compartment a bit easier especially now that I have hardura down. I am looking for more clearance under the seat frame to remove the compartment lid. I have the early 4 bolt per side seat rails and was thinking of simply putting spacers or washers under the mounting ears or using studs from the underside and nuts then sitting the seats on them, but was wondering if the seat mounting ears would take the load cantilevered between them for the long term. Seems like they should, it is only ~50lb per corner, but was wondering if anyone had done anything similar. thanks.
Zack has them for next to nothing...
Attributed to Shayne...
Old January 7th, 2015, 12:19 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
Thanks for the feedback all..
Which vendor is "Zack"?
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old January 7th, 2015, 12:28 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
w
Right over here, sir!
90, seats
Relentless Detroit - raising funds to help kids with cancer Jake1996d1 Misc. Chit-Chat 0 July 16th, 2013 02:36 PM
modular seats, load area seats, standard seats mgreenspan For Sale - Parts 4 July 6th, 2013 10:31 AM
Raising bulkhead off of frame chris snell Defender Technical Discussions 16 January 10th, 2013 02:38 AM
Recaro Trend Seats, Jump seats, bench seats, Exmoor tbutzow For Sale - Parts 1 June 12th, 2007 04:39 PM
Anyone want to trade their Stock front seats for Recaro seats? arbik For Sale - Parts 10 March 11th, 2005 10:42 PM
