84 D90 Brake Lights not working - Defender Source
Old January 29th, 2016, 11:31 PM
sulli270
sean sullivan
84 D90 2.5 NA
I am getting my Rover ready for spring time action and looks like my brake lights are not working. The rear fog lights and regular rear lights go on just fine. I'm not sure if this is a new or old problem that i didn't know about, but either way I've been unable to trace the fault using the Haynes manual. Has anybody had a similar problem? Any tips on what to fix? Thanks.
Old January 29th, 2016, 11:38 PM
Is there power at the switch on the top of the master cylinder?
Old January 29th, 2016, 11:40 PM
sulli270
sean sullivan
84 D90 2.5 NA
I'll try that tomorrow. Is that a common issue?
Old January 29th, 2016, 11:52 PM
It is without a doubt the place to start after checking the fuses and bulbs.
Old January 30th, 2016, 04:03 AM
liquidator
Mark Whiteman
2002 Defender TD5
Could be an earth. I've a similar issue on my TD5 and it seems to be a dodgy earth. It's a pig to trace though.
90, brake, d90, ht, lights
silly electrical system-Haz lights not working El Solis Defender Technical Discussions 16 October 15th, 2014 09:07 PM
LED front lights not working D904evr Defender Technical Discussions 8 August 29th, 2013 07:34 AM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 02:12 PM
Brake lights not working FlaD90 Smaller Projects 3 August 18th, 2008 04:29 PM
top warning/indicator lights not working draaronr Defender Technical Discussions 2 May 22nd, 2008 07:43 PM
