84 Canadian Military D90 - Wheel Replacement Recommendations - Defender Source
Old January 25th, 2016, 07:22 PM
sulli270
sean sullivan
84 D90 2.5 NA
I'm looking for recommendations on replacement wheels for my D90. Right now I have Canadian Military spec wheels that came with the truck that rock the 7.50R16c Michelin XZL tires, cool for what they are but a bit difficult to find replacements for and not that practical. I would ideally like to go to 32 or 33 inch tire with a 16 inch wheel (maybe 285/70/R16 or 285/75/R16). I'm not sure if I need to buy special wheels given the military history of the vehicle or if any standard steelie will work so I posted a pic below. Thanks in advance for any input.
Old January 25th, 2016, 07:25 PM
jafir's Avatar
jafir
Jafir Elkurd
Looks like wolf wheels. They should be fine with other tires if you don't want the XZLs anymore.
Old January 25th, 2016, 08:14 PM
sulli270
sean sullivan
84 D90 2.5 NA
Yeah, it says on the dash that they have "special wolf wheels" I would imagine they can fit other tires but they are a bit narrow. Ideally I would want to go wider, just not sure if there is anything I have to take into account when purchasing replacement wheels.
Old January 25th, 2016, 08:15 PM
Wolfs wheels. A great choice. 265/75R16 for a 32" or 255/85R16 for a 33" are good fits.
Old January 25th, 2016, 08:19 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
This.
Any other wheel is not going to look right on your 90 either.
Old January 25th, 2016, 09:33 PM
I have a set of those wheels with 285'75's on them. Aired them down to 14psi and wheeled the hell of them many times.
Old January 25th, 2016, 09:38 PM
sulli270
sean sullivan
84 D90 2.5 NA
hmm I didn't know you could get these much wider than what I had. I guess that I'll go for the same style wheel, just wider and maybe some lug nut extensions. Thanks for the input guys.
Old January 25th, 2016, 09:42 PM
The wheel doesn't come wider. You can run considerably wider/taller rubber on the wheels you have.
Many consider the nato/wolf wheel to be the best steel wheel available for the defender. If you hadn't noticed they are made of .25 steel.
Old January 25th, 2016, 10:46 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
What size tire are you looking to run?
I've seen 315 width tires on Wolfs.
Old January 25th, 2016, 10:49 PM
jafir's Avatar
jafir
Jafir Elkurd
If you stick with stock wheels there isn't much width to gain. I think the wolfs are 6.5" and disco/defender alloy or disco steel wheels are 7"
You'd have to go aftermarket to get much more width.
90, ac, d90, wheel
Canadian d90 imported 12 years ago Avahdani Misc. Chit-Chat 6 October 14th, 2014 01:45 PM
Wheel stud replacement rear wheel richord Defender Technical Discussions 3 April 17th, 2014 11:45 PM
Canadian 1/4 ton military trailers Uncle Douglas The Flea Market 2 November 9th, 2010 07:37 PM
1994 Yellow NAS D90 - Canadian Truck FS DonFromWhitby For Sale - Vehicles 1 November 16th, 2009 03:24 PM
