'83 starter motor wiring / relay? - Defender Source
Old November 16th, 2008, 10:17 AM
turbodave
Dave C
1983 110
So I had a strange thing happen in cranking my '83 diesel - the engine continued to crank when the key was released. Luckilly - the battery was a little flat as the kids had been playing inside it and left the lights on, such that the engine didn't have enough energy to actually fire.
I also happened to have the battery box open, so it only took me 30 secs or so to disconnect the battery.
After re-touching the battery terminal, it was all normal again.
So i pulled the wiring diagram out, took off the dash to look at the ignition switch, and it was this point that I concluded my '83 must have started life as a 2.25 gas, not a diesel.
Reason I conclude this, is because the diesel versions have a wire from the ignition switch straight to the starter; the gas versions run the switch to a relay, then to the starter. Also, the heater idiot light on the dash was not factory wiring.
So what I can't figure out is why do it differently? And surely the diesel would be the one you'd want to put through a relay with it's heavier starter ciircuit demand?
Old November 16th, 2008, 10:40 AM
this happened on my 200 tdi and it was the starter solenoid.
motor, relay, start, starter, wiring
starter solenoid relay ini88 Defender Technical Discussions 0 July 4th, 2009 10:25 AM
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 02:28 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
