'83 110 Ujoint - Defender Source
Old September 7th, 2008, 10:01 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
'83 110 Ujoint
Okay, searched the forum and searched autozone and NAPA and found that the '93 110 rear driveshaft ujoints were the same as the front. So I bought ujoints from Autozone (all the same) and had them replaced in my 110. Front driveshaft went fine. The rear, however, appear too small. There is a gap between the c-clip and the cup. So I guess my question is: What is the part number for a replacement ujoint for an 83 110? I don't want the biggest/baddest, just a ujoint.
Old September 7th, 2008, 11:44 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Here goes ...
Precision 344 or 369, or Spicer 5-153 or 5-4
It one or the other can't remember witch.
Good luck !
Pat
Kirk Lazarus, Tropic Thunder
Old September 8th, 2008, 08:26 AM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Hey Neil,
They are 344's. and FYI they are the same as a Volvo 700 series u-joint but w/o the grease nipple.
BTW, are you going to Moab?
Cheers
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old September 8th, 2008, 04:10 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Thanks Scott. I searched for the Precision 344 and found this site
http://www.lrfaq.org/RR/RR.u-joint_replacement.html
They also said that it cross-references with the PDQ-1005, which is what the Autozone site came up with, so it looks like I used the right part. I think the guy just really f'd up my driveshaft ends such that there is now a gap. Almost like he spread them apart while attempting to get my old ones out.
Looks like I'm just going to have to bite the bullet and go to a driveshaft shop like I should've done in the first place and see if they can resurrect what's left.
No, unfortnately I'm not going to MOAB. I'm stationed in VA still and any free time is spent going back home to CT. It has been great, though, to become part of the NOVA crowd. I heard you may be moving back to New England?
-Neil
Old September 8th, 2008, 05:48 PM
roverx's Avatar
roverx
Scott Preston
Don't know how much they charge for rebuilding the drive shaft but a new tom woods is only about $350 and worth every penny.
Yes, the house is up for sale and we are moving back north as soon as it sells. Looking at Portsmouth NH. We have already set up an office in town so now we just need the house to sell and we are there.
As for Moab, I had a choice of that or MAR. Having never been out west, it was really on the must do list. I will give a shout to everyone on my mail list once I move.
Scott Preston
Old September 8th, 2008, 06:04 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Neil, let me know if you need to borrow my shaft for MAR, you're more than welcome to it. Ujoints are in fine shape.
Old September 8th, 2008, 07:25 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Thanks Tony.
Okay, I pulled the rear DS tonight and compared it to the front. Definately a size difference in the carriers/forks which would account for the gap between the cup and c-clip.
So, either '83's used a different sized (larger) rear DS, or the PO installed a custom DS. The old ujoints are in a dump somewhere so no luck there. Hopefully the DS shop will be able to measure and find the correct UJ.
Old September 8th, 2008, 08:13 PM
forget which is which but I know the series trucks use two diferent ujoints. one is precision 369 and the other is precision 344.
cup diamter is the same but one has a cap to cap measurement of 2 15/16" and the other is 3 7/32." could be you need the bigger one?
edit: also keep in mind your truck has had a drivetrain conversion AND is 25 years old so the shafts could be just about anything. same goes for just about anything on the vehicle. once you figure out what you have, make a note of it for next time.
Originally Posted by steinhnj
Thanks Tony.
Old September 8th, 2008, 08:29 PM
Neil, I'll see if I can make time to compare mine tomorrow, but my recollection was that my rear matched my fronts (based on external carrier measurements). I used PDQ 1-0153 from advance for the fronts if that helps (it cross referenced to one of those spicer numbers and have a grease fitting). I was going to do my rears just as a precaution but never got around to it.
charles
Old September 8th, 2008, 08:47 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
charles
That's interesting, I used PDQ 1-0005 for the fronts. Maybe the PDQ 1-0153 are larger. If they are, I'll try them. They did have the same cup size as Dave mentioned in the above post.
NAS 110 cage on a 83 110 Uncle Douglas Smaller Projects 14 April 22nd, 2010 11:21 AM
Will new rear door fit an 83 110 Stork17 Defender Technical Discussions 8 November 7th, 2008 08:56 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
