83 110 fuel filler question - Defender Source
Old January 6th, 2015, 01:20 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
For those that will be quick to say search, well I have and I am not finding a clear answer, so I will give this a shot.
My new to me 110 200tdi from disco started as a 2.25 petrol. It has the large style metal fuel filler and leaks diesel from the cap. So in my reading I found that it may have the wrong cap, venting etc. I bought a new style plastic filler but the style is way different and not sure it's going to work.
I know fuel leaking or seeping seems to be common with the older style.
What is the best course of action that I should take. I don't know anything about the conversion. It was done in the UK.
Thank you. Be gentle.
Old January 6th, 2015, 01:32 AM
What about just replacing the gasket on the cap?
Old January 6th, 2015, 07:21 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Picture of your cap? After looking at the seal in the cap I would also look at the tank vent and make sure that it is clear.
Old January 6th, 2015, 07:24 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Werrea View Post
For those that will be quick to say search, well I have and I am not finding a clear answer, so I will give this a shot. My new to me 110 200tdi from disco started as a 2.25 petrol. It has the large style metal fuel filler and leaks diesel from the cap. So in my reading I found that it may have the wrong cap, venting etc. I bought a new style plastic filler but the style is way different and not sure it's going to work. I know fuel leaking or seeping seems to be common with the older style. What is the best course of action that I should take. I don't know anything about the conversion. It was done in the UK. Thank you. Be gentle.
Mine does the same and suspect the gasket has seen better days. If you find a replacement gasket please let me know and I'll do the same.
Clay
Old January 6th, 2015, 07:33 AM
I converted mine to the newer style from the mid 90s. Still leaks, got over it.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old January 6th, 2015, 08:13 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The only time my fuel filler cap has leaked is when it was not in place.
Anthony: show us what you've got... pictures please:
Cap on filler.
Underside of cap.
What is the condition of the gasket?
Also are you filling it up to the very top of the filler neck?
RDavisinVA
Old January 6th, 2015, 11:01 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
Here is what I have. The rubber under the cap seems in good condition. Thin and flat. There is a vent line underneath. Don't know if it is blocked but will check. I did fill up a little more than I should have. My first fill up. But that was a few days ago and 100 miles into the tank. My cap was dripping wet with fuel. Click image for larger version
ID:	110252Click image for larger version
ID:	110253Click image for larger version
ID:	110254Click image for larger version
Old January 6th, 2015, 11:27 AM
That is the super early style.
I would go for the later, but not new type as you can still use the jerry can extension you have.
http://www.paddockspares.com/ntc2676-fuel-filler.html
http://www.paddockspares.com/stc4072...lug-black.html
http://www.allbrit.de/UNI.cfm?PAGE=759025&SPRACHE=EN
Old January 6th, 2015, 05:28 PM
toad's Avatar
toad
Cutter
I had that style on my SIII. Always leaked, new seals, new caps. Gave up trying.
Old January 6th, 2015, 05:54 PM
seals on the caps I have like that are leather. I'll happily take the old filler neck and cap if you upgrade.
Old January 6th, 2015, 06:41 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Anthony:
In the picture you actually have the cap incorrectly positioned.
The raised strip with 2 holes goes perpendicular to the horizon, not slanted as you have it positioned.
I know it will lock in that position, but the picture shows the cap incorrectly placed.
RDavisinVA
Old January 6th, 2015, 08:14 PM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
I will reposition and see what happens. Who knew. Otherwise I will try the newer style.
Old January 6th, 2015, 08:39 PM
like so. -Jeff
Lots of fuel thieves in your hood?
Old January 6th, 2015, 09:39 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
When our son was in NY with our 110, someone stole the fuel filler cap.
RDavisinVA
Old January 6th, 2015, 09:44 PM
I believe that's mine. I took the hasp off shortly after getting the truck.
Originally Posted by pendy
I'm here for the D's
110, fuel
NAS 110 Fuel Filler Tube Ronanmd1 Wanted 2 September 2nd, 2010 08:49 AM
Source for fuel filler hose D90user Defender Technical Discussions 24 October 22nd, 2009 04:12 PM
Fuel Filler Extension John_Karlsson Defender Technical Discussions 8 September 25th, 2008 09:00 PM
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
fuel filler hose mattdh Defender Technical Discussions 2 October 31st, 2003 08:17 PM
