83 110 front axle upgrade questions - Defender Source
Old October 29th, 2012, 12:01 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
With a 83 110, what will need to be swapped to go to 24 spline GBR HD front axles. The diff and axles is a given and I have that. I just wasn't sure what else might need to be changed due to how early the axle is?
Since I have a complete spare front axle out of a disco and RRC I thought I might start stripping the stuff I'll need now.
Unknown Author
716-898-8153
Old October 29th, 2012, 12:54 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Check to see what width radius arms you have? The older ones might be thinner than the new one thus the Disco axle mounting bracket may be different. Pretty much everything else should mount up.
Also check the swivel balls to make sure that they have the correct mounting holes if you are not using the Disco stuff. (they should) Depending upon what calipers you are using the brake lines may need to be adjusted. It would be a great time to upgrade to the Defender vented disc brake set up.
Land Rover 110
Old October 29th, 2012, 12:59 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
So I would need to swap the whole axle casing? Or could I just do from the axle tube flanges out? The disco axle is non vented discs as well, the RRC has a vented disc set up, not sure how I would work out using the RRC calipers though since they are twin lines.
Unknown Author
716-898-8153
Old October 29th, 2012, 01:11 PM
Yes, just swap the inner axles and diff. Everything else is better than the newer axles.
Old October 29th, 2012, 02:07 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Are you guys saying the stock early cv's are better than the gbr heavy duty axle set? I know they are stronger than the disco and later rrc stuff.
I'd say call Bill and ask him what you will need. He's always been helpful with this kind of info from my experience. I'd think if you are swapping the 3rd member and the axles/cv's you'd be all set but maybe you need a different drive flange at the hub but I don't think so.
Daniel
Old October 29th, 2012, 02:41 PM
I think people are confusing terminology...
You MUST buy aftermarket halfshafts, 24 spline inner, 23 spline outer. Any supplier, Ashcroft, GBR, Rovingtracks will all be fine.
You want to install a strong 24 spline differential. Either genuine 24 spline or an aftermarket one of some variety.
The early axles (when I say axles, I mean the entire axle assembly) are better since the CV joints are quite a bit stronger than the later model CV joints. These joints are required to match the 24/23 spline halfshafts. Later axles while require changing and modifying to suit different CV joints. You can buy Chrome-Moly CV joints which are strong again but they are expensive and not needed for everyone.
The early axles also have a wider hub bearing spacing which is better than the late model axles. 110 axles also have larger brakes than the Disco and RRC axles.
Old October 29th, 2012, 02:50 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Using Jon's terms (I'm sure are the right terms lol)
I have a 24 spline front disco third member.
I have the 24 spline GBR stage 1 half shafts as pictured here http://gbrutah.com/cs_drivetrain_axl..._abs_stage_one
Is there anything else I have to change?
Unknown Author
716-898-8153
Old October 29th, 2012, 03:10 PM
No, but you do not want to use a stock Disco front differential. They are quite weak and break on street driven trucks. You are not gaining any strength over the current 10 spline setup, IMO.
edit: The link shows Chrome-Moly joints and shafts that match and are intended for the late model axles. If you go that route, you need to make sure he does a version for the early wide hub, as I doubt he does...
Old October 29th, 2012, 03:22 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
ahh so those half shafts aren't usable for the 110. I'll add them to the for sale thread with the ashcroft rears lol.
Thanks gentlemen
Unknown Author
716-898-8153
Old October 30th, 2012, 08:01 AM
Capt Milks's Avatar
Capt Milks
What you have on an early Defender is a 10 spline inner front, shaft? correct You will also have a hub which has a wider spacing between the bearings. You can not use this hub with a Discovery axle set up. The Early Defender will also have a different axle outer flange. That is if the previous owner didn't change things up. The swivel housing on the early Defenders also had a different top bearing. Both the housing and the swivel balls will be different from the newer Defenders and Discovery. You can look at what you have and see the differences.
Since you are rebuilding everything it would be a good time to upgrade to the vented disc. You will have to get some new, or used , calipers. Calipers are cheap and you could get the newer Defender style. You will appreciate the better braking.
Land Rover 110
110, axle, front axle
Axle swap 90 and 110 101 tomaco1 Defender Technical Discussions 6 November 22nd, 2010 08:27 PM
D-90 1995. Front axle question. triathlon616 Defender Technical Discussions 9 September 19th, 2010 10:39 PM
110 front brakes on a 90 Muscat Defender Technical Discussions 9 April 10th, 2008 12:14 PM
2002 Defender 110 rhoadie For Sale - Vehicles 3 August 8th, 2005 05:13 PM
GBR 4.75 3rds and Extreme front axle setup for sale billnsandi For Sale - Parts 2 January 4th, 2004 11:10 PM
