7pin tow/trailer socket wiring diagram help - Defender Source
Old March 17th, 2011, 07:46 AM
Does any one have a copy or a link to the install instructions for a factory 7 pin harness ?
I installed NAS style lights and in the process seem to have unplugged a few wires behind the tail lights. Of course the wire colors don't matchup so I need the install diagram to see what color plugs into what.
Have most of the trailer working again except for brake lights
Old March 17th, 2011, 08:40 AM
Not exactly. Looking at the wire colors in the Rave/Defender/300Tdi category and it looks like R/Bk is running lights, R/Gr is left turn, Gr/Wh is Right turn, Gr/Pu is brake, Bk ground. Have fun.
Old March 17th, 2011, 10:52 AM
Bill as indicated above the issue is that the wire colors for the tow trailer harness are completely different ( only with a Rover). A simple look @ the wires going to the taillights gives me the info on the truck harness colors.
Old March 17th, 2011, 12:49 PM
TS888's Avatar
TS888
Tony Sims
1984 110
They're wired to a UK standard shared with Europe.
http://www.towbarsrus.com/bar-tow-wiring.htm
Tony
1984 110 "Smokey" (sold)
wiring
95 D90- A/C WIRING DIAGRAM (Davia) --> norros Defender Technical Discussions 30 July 7th, 2010 03:38 PM
need 04' wiring diagram for AC Overlander Defender Technical Discussions 0 June 3rd, 2010 09:38 AM
A/C wiring diagram Shane@EVS Defender Technical Discussions 3 August 20th, 2004 08:46 AM
hella wiring diagram Campbell Defender Technical Discussions 1 May 1st, 2004 02:28 PM
300tdi Wiring Diagram? JimC Defender Technical Discussions 20 April 7th, 2004 09:39 AM
