7 LED 24v Truck Lite Headlight - Defender Source
Old October 18th, 2016, 05:10 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Recently acquired a set of new 24v Truck Lite Headlights. Would anyone happen to know if they would work on a 12V system if the correct plug is spliced? A mechanic I chatted with said a 24V LED will work on 12V with no issues. I wanted to make sure before I started cutting.
7 LED 24v Headlight Only - Trucklite Military LED Lamps
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old October 18th, 2016, 06:18 PM
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Originally Posted by Ncrover725 View Post
Recently acquired a set of new 24v Truck Lite Headlights. Would anyone happen to know if they would work on a 12V system if the correct plug is spliced? A mechanic I chatted with said a 24V LED will work on 12V with no issues. I wanted to make sure before I started cutting. 7” LED 24v Headlight Only - Trucklite Military LED Lamps
Don't cut. Make a temp harness and check before you cut.
Old October 18th, 2016, 06:44 PM
Landy_Andy's Avatar
Landy_Andy
Andy
As the spec's don't say 'Univolt 12/24', I'd doubt it... but still worth a try first.
Old October 18th, 2016, 07:01 PM
As far as I can tell all Trucklote 7" leds are 10-30 Volt.
Old October 18th, 2016, 07:03 PM
If you have them hook up 12 Volts and see what happens.
Old October 18th, 2016, 07:16 PM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
there is an adapter from 24v to 12v
Old November 27th, 2016, 06:59 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
Today I spliced in the 24V (Govt.) Truck Lite LED headlights and they worked fine.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
ht
Truck-Lite LED's mlorman Wanted 38 February 5th, 2015 08:17 PM
Truck-Lite LED tail lights Hache Defender Technical Discussions 10 August 31st, 2014 11:48 PM
Truck lite LED headlights josh-man For Sale - Parts 18 July 22nd, 2014 08:56 AM
Truck lite led headlights NikosF For Sale - Parts 3 April 3rd, 2013 08:52 PM
Limited Time (Truck-lite) LED Light Special FlaD90 Vendors 61 February 2nd, 2013 04:27 PM
