6V to ARB compressor - Defender Source
Old May 22nd, 2009, 09:28 AM
First, if you put 6V to an ARB compressor would you expect it to run poorly or not at all?
I was wheeling this weekend and got an opportunity to use my lockers. Well, tried, but the compressor wouldn't come on. I did a little bit of troubleshooting on the trail, and what I found was everything checked out ok - switches, relay, inline fuse, but was only getting 6V to the compressor. This is with the stock ARB wiring harness. Didn't want to hold anyone up so I moved on, but would like to try figure out why it's not working.
Oh, at the time I couldn't find my wire to test running 12V to the ARB (and my stupid choice of mounting location makes it really hard to do). Will do that next time I have the chance, but expect the motor will be fine.
charles
compressor
Oil and an ARB compressor amasaback Defender Technical Discussions 12 April 4th, 2006 02:22 PM
ARB Compressor Problem : Need HELP Jay Defender Technical Discussions 5 December 5th, 2005 09:52 AM
ARB Compressor Install TDI Guy Defender Technical Discussions 5 April 17th, 2005 08:45 AM
ARB compressor & outlets (?) Cube II Defender Technical Discussions 9 December 15th, 2004 03:48 PM
4.11 gears, arb lockers, and arb compressor williasp For Sale - Parts 1 February 27th, 2004 03:15 PM
» Defender Registry
Mabel
mightymo
D90
griffinrr
Add your Defender
