60amp accessory fuse B blowing in main fuse box - Defender Source
Old March 24th, 2013, 04:58 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
Just finishing up an engine rebuild. Reinstalled enginge and attempting to star when we ran into fuse B blowing when ignition switch is turned. Checked big draw suspects and finding nothing. No electrical equipment has been changed.
What does this fuse feed?
Any pointers on how to locate the short?
Truck is a 95nas. Fuse is the 60 amp 'fuse B' in the main fusebox on the engine bay firewall. Fuse is labeled 'Accessories and A/C'
"I think you need a little weatherstripping - right here..."
Old March 24th, 2013, 05:01 PM
Damaged wiring. its shorting.
Old March 25th, 2013, 07:32 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I would go back over the wires you disconnected to make sure everything is where it should be. If all of that is fine then trace all the wires to make sure one didn't get pinched and is grounding out. As Chris mentioned you may have a short since the fuse is blowing right away.
Land Rover 110
Old March 25th, 2013, 09:44 AM
owen's Avatar
owen
Owen Jones
Yes I am pretty sure its a short form a pinched wire. I am trying to narrow it down to the circuits fed by this 60amp 'accessory' fuse. The A/C is of course one of them.
Any suggestions on the other 'Accessory' circuits fed by this fuse would be very helpful!
Thanks!
Owen
Old March 25th, 2013, 09:51 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Give a quick look between the bell housing and the block makes for a nice pinch point that is out of sight.
Old March 31st, 2013, 09:18 AM
owen's Avatar
owen
Owen Jones
Ok, got it.
Power lead to the coil was grounded. Duuh!. Found it by connecting a low watt bulb across the blowing 60 amp socket and disconnected terminals one by one till the light dimmed.
No pinching, just a brain fart.
Thanks for the posts!
ac, wing
'97 main ECU and mounting box dmarchand For Sale - Parts 1 December 11th, 2005 09:19 PM
Fuse Box easy to replace? waveridin1959 Defender Technical Discussions 7 November 5th, 2005 08:11 PM
Repeatedly blowing undehood 30A fuse Hans Defender Technical Discussions 1 September 6th, 2005 04:24 PM
Engine Fuse Box Cover thug1313 Wanted 3 April 20th, 2005 07:26 PM
