5th gear and Reverse sticking - Defender Source
Old May 21st, 2007, 03:34 PM
anthony's Avatar
anthony
Anthony Leung
1995 D90SW #51
Was wondering if anyone had this issue and how it was resolved, it's on a Defender 90 with a R380. My 5th gear and reverse started to stick , found out when i driving home from the last trail I hit. Gears 1-4 are normal , just reverse and 5th. Any oppions much appreciated. I think regardless of what it is, going to pull the box and ship it down to Rob Dassel and Southwest rovers, but i'm just curious if anyone else has had this issue. I've been pretty hard to it, but i've never seen a R380 actually break.
1995 D90sw #51 (Converted to ST)
1997 D90ST
2006 LR3 HSE (untouched... for now)
Old May 21st, 2007, 08:14 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Just in case, did you check your oil level and condition ?
- Charles Eames
Old May 22nd, 2007, 12:09 AM
anthony's Avatar
anthony
Anthony Leung
1995 D90SW #51
I replaced, transmision fluid, transfer case, oil, ... Only thing i really didn't change is the Diff, which is less than a week old sigh. I've got a few good guesses from a few LR mechs, it's down two either the syncro mesh , since it's a 5th,R thing which isn't even in the main house which would make sense it would be just those two, or the gate linkage... Hydrolic has been pretty much rules out because 1-4 is fine, which also rules out the clutch.
1997 D90ST
Linkage - gear box shot ? My 1st time (pop!) paulb Defender Technical Discussions 10 January 21st, 2008 07:07 PM
Reverse problems tmore Defender Technical Discussions 1 October 25th, 2005 05:12 PM
reverse gear... Gkase Defender Technical Discussions 1 September 29th, 2004 06:13 PM
Getting into gear, but not *moving*! chris72982 Defender Technical Discussions 3 February 9th, 2004 12:38 PM
HELP!! I can't put my tranny in gear... JRowe Defender Technical Discussions 1 October 12th, 2003 12:07 PM
