5 Pin Dash Connectors: Fogs, R. Wipers, Heated WS - Defender Source
Old November 17th, 2013, 05:28 PM
BlackField's Avatar
BlackField
Oscar
D110
Hello again,
I'm off to the next phase of rewiring and I'm up to the dash and all of its AMP Tyco connectors.
can someone explain the connector's 5 pins. I've come across some unclear info on the net. I'm fairly certain 3 is ground but everything else is unclear.
EDIT: found some info that I'm going to plug in and if someone can correct it great.
If you know a pin's label hook me up.
YUG000350LNF (w/ white connector)- rear wiper
1
2
3
4
5
YUG000470LNF (w/ blue connector)- fog light
1
2
3
4
5
YUE000070LNF (w/ blue connector)- rear washer spray momentary switch (think i have the same switch to rear screen heater also)
1
2
3
4
5
Unknown (w/ black connector)- rear window defrost momentary switch
1 Fuse box
2 Night-time illumination - live feed from the dashboard/clocks
3 Not used
4 Heated rear screen relay
5 Ground
Unknown (w/ green connector) Heated Windshield momentary switch
1 To heated front screen timer unit
3 Not used
4 Ground
5 To heated front screen relay
AMR 3602 (w/ green connector) RH heated seat switch
1
2
3
4
5
AMR 3601 (w/ white connector) LH heated seat switch
1
2
3
4
5
I'll also take any info on the hazard, heated seats, and per window switches if you know them.
Oscar
Old November 18th, 2013, 10:38 AM
BlackField's Avatar
BlackField
Oscar
D110
Just got this email from Paul over at LR Connectors:
Hello Oscar,
YUG000350LNF - Defender Rear Wiper Switch.
This switches the coil of the Rear Wiper Relay to earth.
Pin 1 - From Rear Wiper Relay coil
Pin 2 - Illumination live
Pin 3 - Not used
Pin 4 - Earth
Pin 5 - Not used
YUG000470LNF - Defender Heated Rear Window Switch.
This switches the live to the Heated Rear Window Relay.
Pin 1 - Live in from fuse box
Pin 3 - Not used
Pin 4 - Switched live out to Heated Rear Window Relay coil
Pin 5 - Earth
YUE000070LNF - Defender Rear Washer Switch.
This momentarily switches the live to the Rear Window Washer Pump.
Pin 2 - Earth
Pin 3 - Not used
Pin 4 - Switched live out to Rear Window Washer Pump
Pin 5 - Illumination live
AMR3602 - D1/RRC RH Heated Seat Switch.
This switches the live to the RH Heated Seat Relay.
Pin 3 - Not used
Pin 4 - Switched live out to RH Heated Seat Relay coil
Pin 5 - Earth
AMR3601 - D1/RRC LH Heated Seat Switch.
This switches the live to the LH Heated Seat Relay.
Pin 3 - Not used
Pin 4 - Switched live out to LH Heated Seat Relay coil
Pin 5 - Earth
Regards,
Paul.
Old November 23rd, 2013, 11:36 PM
BlackField's Avatar
BlackField
Oscar
D110
YUG000740 - D2 Hill Descent Control Switch (changed cover to blank to repurpose to an ON/ OFF switch)
Pin 1 -
Pin 2 -
Pin 3 -
Pin 4 -
Pin 5 -
YUG000530LNF - Switch Rear Fog (plan on using this to run my Fog Lights)
Pin 1 -
Pin 2 -
Pin 3 -
Pin 4 -
Pin 5 -
YUG102550 - Switch Heated Windscreen (green connector, momentary switch)
Pin 1 -
Pin 2 -
Pin 3 -
Pin 4 -
Pin 5 -
Would anyone happen to have a connector for a D110 Hazard Switch 2002 on (YUG000180LNF) and know the pin information for it?
What about the pin information for D1 power window switches (AMR2496)?
By the way I'm using this as a log for my wiring process. It looks like I have more than one switch that has had its button replaced with another cover so take my connector colors with a grain of salt.
Oscar
Old November 24th, 2013, 05:13 PM
BlackField's Avatar
BlackField
Oscar
D110
Old November 24th, 2013, 06:09 PM
Contact will tillery perhaps he'll cut the looms and sell you the connectors you need.
dash
Wanted - 5 pin TTS connectors cgalpin Wanted 38 April 23rd, 2016 01:06 PM
LHD Dash CDeWan For Sale - Parts 32 October 3rd, 2012 05:03 PM
Iron Goat Defender Dash Kit - Brand new nickt For Sale - Parts 5 June 28th, 2010 06:21 AM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
