4pin trailer plug in a TD5 crossmember opening - Defender Source
Old January 24th, 2016, 07:43 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
So I'm thinking of removing/unplugging the euro 7 pin socket from my harness (1997 row) and converting it to a standard North American flat four pin. My new chassis has a td5 rear crossmember with the specific opening for a socket and I'd really like to anchor the four pin in there and in a perfect world have some sort of protective door covering the socket (similar to a 7 pin or blade socket).
Anyone done anything like this yet? It seems most four pin plugs are pretty flimsy and can't easily be anchored.
Old January 24th, 2016, 08:02 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Ok that four flat mounting box might be the ticket.
I don't think I can fit the 7 spade box in the opening in the crossmember without some butchery. I'm also not planning on adding a brake controller at the moment either.
Trying to keep it kind of clean looking. I was originally just going to use the euro 7 with an adaptor but my old ones in rough shape and if I can eliminate an adaptor it's a bonus.
td5
Pandoras Box is opening... atlcruiser The Vendors Loft 6 November 20th, 2014 04:30 PM
Right front wheel opening flair 97 rayfi Wanted 3 November 26th, 2008 06:45 PM
Paint/Body tech job opening ECR Wanted 0 November 19th, 2007 05:33 PM
Safari Gard Hitch opening themaxx Defender Technical Discussions 9 August 31st, 2007 08:16 PM
Opening a Dealership wicks Misc. Chit-Chat 30 March 4th, 2004 11:57 PM
