4hp22 - Defender Source
Old August 2nd, 2010, 12:46 AM
orionpco
larry burns
1962 series 2a
4hp22
i am wondering if the is any electronic control from the the ecu on a 1988 rrc to the trans
seems to have one connection point . can anyone rell what that connection is for?
Old August 2nd, 2010, 08:51 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi larry I think it is the reverse light and start inhibit which go to a 4Way plug on the Rh side of the box near to the shift linkage.
Regards
Gren
Old August 2nd, 2010, 01:35 PM
orionpco
larry burns
1962 series 2a
thank you im thinking of using this trans in a project and its very hard to find any lituerature on this transmission.
Old August 2nd, 2010, 02:36 PM
Very, Very, common transmission made by the german company ZF. Used in all 1980> BMW 3,5,6, and 7 series up until they went to the 5 speed auto's. Some of the higher spec cars had the EH or electronic handling which changed shift points and offered a normal, sport, and economy modes. It was used in the Ranges Rovers from 87-95 and Disco's to 99, as well as Jaguar XJ 6's and XJS, Maseratti's and some Porsche's. There are litterally a million of these transmissions out there. I have put clutch packs and torque converters in a bunch of them and they are easy enough to work on. If you google ZF 4HP22 you should be able to find out more than you want to know.
ZF 4HP22 Transmission phoenix37 Wanted 5 March 25th, 2010 11:53 AM
Transmission Ratios? Hammertime Defender Technical Discussions 12 August 6th, 2009 09:30 AM
