4CU --> 14CUX conversion - Defender Source
Old October 9th, 2012, 10:04 AM
neduro
Ned Suesse
1987 D90
Looking for advice on taking my computer from a 4CU to a 14CUX.
Before I started looking at wiring diagrams and trying to figure out what I have vs. what I'd need, I thought I'd ask here and see if anyone's done it.
Questions of note:
- Will the sensors I have work for the new computer?
From measuring the 2002 stuff vs. what I have, I know the temp sensors, Throttle Position, and MAF all have different ranges depending on age of vehicle...
- What additional inputs are required for the 14CUX? Presumably, it needs more information than my existing computer, and I'd have to sort those inputs.
This thing is not going to get the best of me!
Old October 9th, 2012, 11:46 AM
What is a 4CU?
Do you mean a 13CU like on an 87 RRC or do you have a "flapper" style ROW injection system?
Old October 9th, 2012, 12:27 PM
neduro
Ned Suesse
1987 D90
Originally Posted by evilfij View Post
What is a 4CU?
My reading indicates that very early US range rovers had the 4CU, but I don't know that to be true for sure. It definitely was common ROW. It has a flapper style MAF.
I think the parts on my truck originated in an early 80's british rover.
Old October 9th, 2012, 01:41 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I am in the process of using a Td5 main harness and a 14cux engine harness with a made up transmission harness. Most everything you will be changing will be in the engine harness I would think? The computer need very little aside from what is in the engine harness. Do you have a 14cux engine harness, if not you should be able to source a old Discovery harness. PM me your email and I can send you a few wiring diagrams if you don't have them.
Land Rover 110
Old October 9th, 2012, 01:52 PM
If you have a flapper, I would just swap everything over from a 14CUX truck, but I have no idea how to do that short of getting a donor RRC or DI and taking everything. I don't know if anyone this side of the pond has done the conversion you are trying to do as all US spec trucks had the "hotwire" 13CU/14CU/14CUX set up.
Old October 9th, 2012, 01:56 PM
Yep, just pull everything including the harness from the donor and swap over.... With a copy of the wiring schematic, it is quite simple.
Old October 9th, 2012, 02:07 PM
neduro
Ned Suesse
1987 D90
What years of RR would have the 14CUX?
Old October 9th, 2012, 03:11 PM
Mid 93-95, but a 14CU is just as good you just get a soldered in chip. What motor do you have now? It might be easier just to swap a whole running motor at the end of the day. A 4.2 out of an LWB has nice power gains over a 3.9 or a 3.5.
Old October 9th, 2012, 04:41 PM
neduro
Ned Suesse
1987 D90
Just finished swapping in a motor... a 4.0 from a 2002 Disco. It runs exactly the same (+ maybe 10%) as the old 3.5, leading me to believe that the 4CU is the weak link.
Old October 9th, 2012, 04:53 PM
What front cover did you use the one off the original 3.5? What intake is on it?
You will need O2 sensors and everything, but assuming you have the old front cover, I would look for a 1990-94 rrc and use that stuff.
Old October 9th, 2012, 05:06 PM
neduro
Ned Suesse
1987 D90
Here's a picture of the install:
You can also follow my thread about the swap in all its painful, shameful detail:
http://www.defendersource.com/forum/...t.php?p=354629
Basically, I liked the intake manifold from the 2002 a lot more than the old POS that was on it (which is essentially the same one that would be on a 14CUX). So, I spent way too much time carefully fabbing solutions to mount all the sensors/ plumbing I needed onto the new manifold... to discover that my problems did not stem from the old manifold.
I think I'll go drink for a while now. :-)
------ Follow up post added October 9th, 2012 03:12 PM ------
To answer the rest of your question, front cover is from a ~83 3.5, cam is a crowther with dist drive, and intake is the madness above.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
