41% discrepancy between exhaust ports and manifold - Defender Source
Old February 13th, 2012, 11:52 PM
cdb
Clark Bowen
I measured the surface area of the exhaust ports and they are 665mm square per port = or 2,660mm square from one bank of the motor.
However, where the manifold meets the NRP downpipe the surface are is reduced to 1,578mm.
Isn't that a 41% reduction in air flow?
Is there some aspect of fluid dynamics that I'm missing here or does this seems like a substantial restriction.
If headers changed this, it would seem like there should be a substantial performance gain from them?
2011 RR HSE -
2001 GMC 2500 4wd
Old February 13th, 2012, 11:58 PM
4 stroke. The cylinders are exhausting around 1/3 of the time.
Old February 14th, 2012, 12:15 AM
cdb
Clark Bowen
Duh.
Of course.
2011 RR HSE -
2001 GMC 2500 4wd
Old February 14th, 2012, 08:25 AM
Funny, they could have shortened the book down to one page!
If I remember correctly, 'Tuning the Rover V8' had recommendations for various set ups. One being to use the Buick 300 crank and heads. You could go crazy and port match the heads an manifold, get headers etc. But really, SBC is the biggest bang for the buck.
-Jeff
Old February 14th, 2012, 08:59 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Exhaust gas temperatures will drop several hundred degrees C by the time it reaches the end of the exhaust manifold. As gas cools it occupies about 1/273 less volume for each 1 degree C in temperature.
Old February 15th, 2012, 12:03 AM
cdb
Clark Bowen
So if I ceramic coat the exhaust manifolds then there will be more volume as it flows into the downpipe than if I left them stock?
If it drops 273 degrees C, for illustration purposes, does that mean there is nothing at the downpipe? Of course not, but I don't understand how it works out in the real world. I'm curious. Thanks
------ Follow up post added February 14th, 2012 09:04 PM ------
Jeff....
What is "SBC"?
2011 RR HSE -
2001 GMC 2500 4wd
Old February 15th, 2012, 06:47 AM
Short blonde chick
Old February 15th, 2012, 12:53 PM
cdb
Clark Bowen
Originally Posted by rover4x4 View Post
Short blonde chick
Had one of those for the past 27 years. Highly recommended.
2011 RR HSE -
2001 GMC 2500 4wd
Old February 15th, 2012, 01:49 PM
What is "SBC"?
Small Block Chevy, I'm guessing.
Old February 16th, 2012, 08:20 PM
cdb
Clark Bowen
Probably better. The Chevy would be cheaper in the long run than the other type of SBC.
2011 RR HSE -
2001 GMC 2500 4wd
exhaust
exhaust manifold temp? MUDSUX Defender Technical Discussions 4 November 19th, 2009 08:43 AM
300Tdi exhaust manifold problems crown14 Defender Technical Discussions 12 July 8th, 2009 11:38 AM
Whistle noise from exhaust manifold? markurski Defender Technical Discussions 11 November 27th, 2007 08:39 PM
Cracked Exhaust Manifold jamieh64 Defender Technical Discussions 9 November 22nd, 2005 01:04 PM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
