4 Wheel / Diff Lock - Defender Source
Old August 7th, 2007, 08:37 AM
hamiamham
mike
97 D-90
4 Wheel / Diff Lock
I have a 1997 D-90. While I realize the truck is in full time 4-wheel drive, Im a little confused about when to lock the differentials. When I go over soft sand for longer drives I usually air down the tires to about 15psi and lock the diff in high by moving the lever all the way to the left. On short stretches of sand I usually just leave it in the normal diff-lock off position. This past week I needed to drive over about 100 yards of soft sand. With diff lock off and full air in tires I got about 25 yards and started to bog down. I put diff lock on (high setting) and slowly accelerated; nothing. Wheels not moving. Aired down the tired and tried to move the truck in diff-lock off position. Still bogged. Move the difflock into lock high engine spun for a few secs and with a thunk it engaged and I was able to back out onto the road again. Mechanic said I should never have to lock the differentials unless Im really bogged down deep in something. Would appreciate your opinions.
Old August 7th, 2007, 03:13 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Lock the center diff before you get bogged down. While you are still rolling.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old August 7th, 2007, 04:42 PM
yep. even if you think you might need to lock the center in its best to do it before you need it.
Old August 7th, 2007, 08:39 PM
hamiamham
mike
97 D-90
thanks guys
Old August 7th, 2007, 08:50 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
only lock it when you're moving if driving very slowly. you don't want to slam the teeth in your transfercase by engaging lock with the axles turning at different rates..
and disengaging might not happen immediately. usually a little slow reverse action lock/unlock slow back and forth will get the thing to disengage.
GENTLE!
have fun
~Steve
wheel
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
Diff Lock Andrew Vick Defender Technical Discussions 3 August 26th, 2007 10:05 AM
need one wheel lock draaronr Wanted 3 September 22nd, 2004 11:37 PM
