4 Bolt Steering Box Input Shaft weirdness. - Defender Source
Old April 14th, 2015, 04:41 PM
mech's Avatar
mech
Its Me
1991 110 CSW
Hey all.
In an attempt to tune up the steering responsiveness on my 110 tdi, I've replaced a lot of bits. These include:
New 4 bolt OEM LR steering box.
New style Steering Shaft to match the 4 bolt.
New tie rod ends
New Bushes
New Steering Damper
New shocks and Springs
And I still have about an 3/4 inch of play in both directions at the steering wheel.
I've noticed that the new 4 bolt box input shaft does not have splines all the way to the end of the shaft. Instead the end of the shaft is turned down to a smaller diameter. This causes the lower u-joint to wobble a bit on the shaft even when its fully tightened.
Has anyone else observed this small play between their input shaft and the lower u-joint? I've tried two different u-joints and one is from a good supplier, so it shouldnt be a parts tolerencing problem.
-Thanks for any help
Old April 14th, 2015, 06:03 PM
Get it up off the ground and check for wobbly swivels.
Old April 14th, 2015, 06:29 PM
sounds like maybe you got a disco II box?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old April 14th, 2015, 06:45 PM
I have the same - some very small amount of play between the steering input shaft and lower u-joint.
It does manifest itself as a little bit of play at the steering wheel.
My truck is a 1984, so it's possible that it's just old. Not sure why your new steering shaft is having the same issue.
Old April 15th, 2015, 02:34 AM
mech's Avatar
mech
Its Me
1991 110 CSW
Swivels are solid. It's definitely at the shaft. I can see the movement.
Interesting idea about the disco box. I'll check into it. Should be the right part. I bought it directly from a LR dealer in England.
Ignition weirdness defdad Defender Technical Discussions 1 April 5th, 2015 04:37 PM
300TDI R380 input shaft, or entire transmission jaherring Wanted 1 June 15th, 2010 11:33 AM
R380 Transmission Input Shaft Bearing Question Heath Defender Technical Discussions 0 March 15th, 2007 03:09 PM
MAF/intake weirdness artm Defender Technical Discussions 1 August 7th, 2006 06:07 AM
T-case input shaft Bearing #s Mike Hippert Defender Technical Discussions 10 June 8th, 2005 06:52 PM
