4.6 vs. 4.6 HSE- what is the difference? - Defender Source
Old November 30th, 2009, 02:43 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
If anyone can shed some light on the differences I would appreciate it. Just not sure what HSE stands for.
Looking to upgrade to a 4.6 and am considering some options.
Also, if I were to rebuild a short block would you just put new rings and main bearings in or all bearings including cam bearings?
Thanks for the help!
Old November 30th, 2009, 02:51 PM
The HSE is the trim package for the truck... The 4.6's is either a GEMS or a Bosch, depending on year. The GEMS motors should be a direct drop in, into your truck, I think they ran from 95 - 00.
Old November 30th, 2009, 03:56 PM
enecks's Avatar
enecks
Justin
94 and 96 5spd Discos
HSE = High Spec Equipment or some such. As woldd90 indicated, it's just a trim package, and you can find more information on the various years with this handy site.
Old November 30th, 2009, 04:37 PM
www.rangerovers.net
Old November 30th, 2009, 06:37 PM
All bearings as well as rings. For a 4.6 you will need to keep your front cover. You also have to modify the pulleys as the 4.6 crank sticks out more. Otherwise more or less straight swap part for part. Use newer composite head gaskets and forego the outer head bolts.
Old November 30th, 2009, 09:51 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Ah makes sense. I really do need to brush up on my Range Rover's!
Thanks for the help. Bill I appreciate the advice.
Tyler
Old December 1st, 2009, 08:01 AM
OOpsie daisy! I reread your post to see that you have the later 4.0 engine. These 4.0/4.6 are pretty much a straight swap. The difference between the 4.0 and the 4.6 is the stroked crank.
There are other things you can do to these, like installing a high lift cam, putting in Ford or Chevy pistons with different compression ratios, porting the heads, installing headers...aluminumv8.com has some interesting ideas.
Want 400-plus horsepower? Talk to those guys.
hse
1997 Range Rover 4.6 HSE woldd90 For Sale - Vehicles 20 September 14th, 2006 09:43 AM
1999 Range Rover 4.6 HSE - Low Miles mlepisto For Sale - Vehicles 0 February 12th, 2006 10:45 PM
1998 4.6 HSE Range Rover $7500 roverover For Sale - Vehicles 0 August 18th, 2005 10:26 AM
2001 Range Rover 4.6 HSE for sale hochung For Sale - Vehicles 1 July 28th, 2005 11:58 PM
2000 Range Rover 4.6 HSE for sale or trade for Defender treydub For Sale - Vehicles 6 February 28th, 2005 10:57 AM
