4.6 Swap? - Defender Source
Old June 8th, 2004, 03:11 PM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
4.6 Swap?
Might be a fun project!
If I do the work myself, how cheap can I do this for?
Old June 8th, 2004, 05:59 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
About $400 plus the price of a 4.6 long block
Old June 8th, 2004, 06:01 PM
Ya a 4.6 long block will do tons of good in a 94-95 d-90
Heads are different, cam won't work, front cover won't work, oil pan won't work if its bosch, etc etc. etc. Buy a short block
Ron
Old June 8th, 2004, 06:15 PM
mind my idiotness but whats the difference between short and long blocks.
Old June 8th, 2004, 06:17 PM
A few grand :-0
Short block is just the block, pistons, crank etc.
Long block includes (at least with rover) oil pan, cam, heads, front cover, water pump, rockers valve covers
Old June 8th, 2004, 08:06 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Assuming he starts with his D90 3.9/4.0, what he will need to do is swap the valve covers, swap the oil pan, swap the front cover, add a cam and lifters that take the distributor (about $250), swap the front cover, get a spacer for the front pulley($30), some gaskets, a can of Right Stuff. Swap out the air management from the 3.9/4.0, new timing gear, and voila. About $400.
Ron, why would the heads not work? I must have missed something.
Old June 8th, 2004, 09:27 PM
Serp belt heads have different bosses that non-serp belt heads. makes bolting up ancilaries a challenege if you have the wrong ones.
So basically what you are saying davis is that he needs a short block and new heads from the long block, however.
1. heads rarely are "bad" beyond what a refurb would fix.
2. Bosch/GEMS heads are not a direct swap
Now on a 97 a GEMS 4.6 long block would be ideal but 94-95 all you can really use is the short block.
Ron
Old June 8th, 2004, 09:51 PM
what about the 4.2? can you use the same "stuff" from the 3.9? I heard (emphasis) that the 4.2 was better than the 4.6 in regards to performance????
4.0 to 4.6 parts? gtg067i Defender Technical Discussions 6 September 11th, 2010 08:40 AM
Year range for 4.6 swap kolvedic Defender Technical Discussions 14 August 25th, 2009 03:43 PM
4.6 swap anthony Defender Technical Discussions 1 June 18th, 2007 09:59 AM
3.9 to 4.6 1995 D-90 boxerhips Defender Technical Discussions 5 January 25th, 2006 07:20 PM
How I can swap 3.9 to 4.6 in 95 D-90? Vadim Defender Technical Discussions 11 September 12th, 2004 11:30 PM
