4.6 chip upgrade check engine light - Defender Source
Old May 14th, 2010, 04:47 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
I just installed 4.6 chips into a 97 D-90 ECU . We finally got the engine running but can't clear the check engine code P1777 gearbox ignition retard request line fault . Has anyone dealt with this before ? The 90 is running great but I still want to pass State inspection .
Old May 14th, 2010, 05:23 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
You can't clear that code as the chip maker used the software from the P38 Range Rover (4.6) for the chip and you don't have the electronic gearbox, so you are stuck with the code.
Contact the chip manufacture, or if you just used RR 4.6 chips then you can't clear it (well you can clear it, but it will come back).
Email:
Old May 14th, 2010, 05:56 PM
jorge's Avatar
jorge
JORGE ESPINOZA
That's what I thought . I was hoping that maybe just 4.6 one chip could be installed and keep a 4.0 chip connected so as to avoid this fault code . I'm going to try the 90 at high speed tomorrow to see the performance difference , if any . Any recommendation on a chip set that will solve this fault code problem .
Old May 14th, 2010, 07:25 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Black tape over the Check Engine light
Jorge, I need you to give Fernando the heads up next week if you know what I mean.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
check engine light, engine, ht
RED Check Engine Light Flagg Defender Technical Discussions 38 July 2nd, 2011 09:31 AM
4.0 to 4.6 parts? gtg067i Defender Technical Discussions 6 September 11th, 2010 08:40 AM
Check Enginge light and Gas Cap floyd650 Defender Technical Discussions 13 December 27th, 2007 05:44 AM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
