4.11 gears - Defender Source
Old May 31st, 2004, 10:31 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
4.11 gears
Are any of you guys running Ashcroft 4.11 gears? I have been waiting for months to get gears from a US retailer.
If so did you buy directly from Ashcroft and about what do they cost? Do they seem to be good quality?
What about their heavy duty axles? Cost and quality?
Thanks for any info.
Old May 31st, 2004, 11:13 AM
tbmcneill
Guest
Posts: n/a
I'm not familiar with Ashcroft gears, but based on firsthand experience, I'd definately stay away from their axles.
I've seen firsthand 3 of their axles break right at the edge of the splines (2 fronts, 1 rear) & have heard of 4 snapping (2 front, 2 rear), as well.
By comparison, I've only ever heard of 1 GBR rear axle breaking & no fronts. And, to my knowledge, we've only had 1 of our front axles break (broke when a CV grenaded) & no rears.
T
Old May 31st, 2004, 01:55 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Aren't GBR axels and R&P made by Ashcroft?
Old June 1st, 2004, 11:18 AM
scoloco's Avatar
scoloco
'94 D90 ST
Dont know if GBR carries Ashcroft stuff, but I do know that Bill will be getting his R&Ps soon. (I've got a set on order, and have been bugging him for status every now and then).
Old June 1st, 2004, 11:43 AM
tbmcneill
Guest
Posts: n/a
GBRs stuff is made by Maxidrive, not Ashcroft. I believe he's contracted with someone here to make his new CVs, though.
T
Old June 1st, 2004, 11:51 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
T
Oh! I had no idea. Thanks Troy.
Old June 1st, 2004, 12:52 PM
truls
truls john thomassen
cv joints
hei i am a member from norway. i have a problem whith my defender 90 300 tdi 1996.
i have broken 5 cv joints and halfshafts on my front aksel the last coppel of years. i am driving whith 35x10,50x15 simex eksrem trekker and arb difflock.. whath are your doin whith yor rigs to make them hold yhe whole way. i have seen pics of defenders whith 37 inch tyres
Old June 1st, 2004, 01:14 PM
http://www.greatbasinrovers.com/axle.html#cvjoints
http://www.rovertracks.com/Axles.htm
Those are a couple places to get upgraded parts and some go the rout of replacing the front end. I have 35s and stock axles and no breakage yet.
Old June 1st, 2004, 02:00 PM
tbmcneill
Guest
Posts: n/a
Truls-
In the front, the weak point is the CV. For the most part, you can buy gears and axles to stand up to the abuse of general wheeling with the stock motor. The CVs are a whole other animal. Every aftermarket CV out there for Land Rovers has been broken at one time or another. I went thru 4 in my 12 months with 37s ... & I'm pretty light on the 'go pedal'.
Most of the upgraded CVs are based off AEU2522s .. the larger 110 CV. Even in stock form they (in theory) hold up better than the stock 90 ones. GBR supposedly has some nice ones coming out soon that are claimed stronger than anything else available yet. They'll be pricey, though. We've got a few things on the table we're looking into to make ours stronger. The goal is to make something not even Yousef can break... .
Of course, you can also drop a front axle from a 101 under your rig or have a custom Dana 60 or 9" built, too. Then you can get 35-spline 1.5" axles & CTM u-joints.
T
Old June 1st, 2004, 04:44 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
T
... and you guys did it. I haven't broken any axle parts from you guys
Knock on wood
Old June 1st, 2004, 09:31 PM
The new trend in Aussyland is to use Longfield CVs (for Toyota Minitrucks) with custom inner shafts and flanges. The stock Toy CVs are basically the same size as the 2522s, just a little bigger outer shaft. The Longfielding make them realtivly bulletproof. You can also put the hypoid Toy centers in with a few mods.
http://www.outerlimits4x4.com/PHP_Mo...pic.php?t=5357
http://www.pirate4x4.com/forum/showt...entre+to+rover
Old June 2nd, 2004, 09:05 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Thanks to all.
Scott, I too have been waiting for GBR gears. Also have been checking status. Hope to have them soon. I'll try to stay in touch with you.
Front end upgrades next year I hope.
Thanks Troy
Old June 2nd, 2004, 06:39 PM
truls
thanks.. i understand that there is many way`s to rebild cv`s on..
Old June 5th, 2004, 10:31 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
RN has a set of 4.11's for $699 on special. thats a great price....
Legend in My Own Mind.
New Gears and WOW, 10 mph? mdmccallum Defender Technical Discussions 26 December 1st, 2011 03:50 PM
4.11 gears ini88 Wanted 0 July 21st, 2008 12:13 AM
Gears vs Tires jimbemotumbo Defender Technical Discussions 21 April 26th, 2005 09:23 AM
4.11 gears, arb lockers, and arb compressor williasp For Sale - Parts 1 February 27th, 2004 03:15 PM
4.10 gears and Detroit locker dave_lucas For Sale - Parts 3 December 1st, 2003 03:03 PM
