4.11 3rd member Anyone? - Defender Source
Old March 2nd, 2008, 08:30 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Arrow 4.11 3rd member Anyone?
does anyone have a 4..11 3rd member that i can borrow and swap into my 88 coil truck to check gearing requirements and performance? I know this is a long shot but hey, I will ask anyway.. The numbers look ok on the calculator but you will never know till you try it..
Legend in My Own Mind.
Old March 2nd, 2008, 06:08 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The Perkins is a high reving TD without huge HP or Torque numbers, perfect for a OD I would think. I will be pulling my Fairey and installing an Hi ratio transfer case very soon on mine if you're interested in a OD. If you have an OD now just baby it from 1 st to 4 th in OD and see if it is OK that way, 4.11s will be halfway between that and an OD.
Old March 2nd, 2008, 06:43 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Kevin, I'm running an lt-77s with a 1.2 lt-230 behind it... Not series stuff... what about a roverdrive? will they work with a 1.2?
OR any other Ideas? I just need for top speed on the road.
Old March 2nd, 2008, 08:52 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
Randy, I have 4.11's on my D2 .. trutrac front, detroit rear.. Not sure if they are swapable with a Series, but if I can be of help, let me know.... maybe we can trade my d2 for you 90 for a few days
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old March 2nd, 2008, 10:37 PM
I thought d2's used a different bolt pattern. randy are you going from 3.5's the engine can't pull or 4.7s that rev too low?
you running 24 or 10 spline or ??
Old March 2nd, 2008, 11:19 PM
rmuller
Ryan
I figure if he's changed to the coil chassis, he may be at 24 spline... so the diff may have the same bolt pattern..
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old March 3rd, 2008, 07:49 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have 4.7's 24 spline...... The rover drive might e the way to go but I am not sure. Does anyone have one?
4.11 third member open carrier abraded For Sale - Parts 3 June 4th, 2010 11:26 AM
Converting to Toyota 3rd member Broke It Defender Technical Discussions 8 October 16th, 2005 09:45 PM
D-90 3rd seat up front ?Possible - How? paulb Defender Technical Discussions 17 October 28th, 2004 07:26 PM
Rear 3rd Member w/ 4.75 gears and Detroit orlandog For Sale - Parts 0 October 26th, 2004 10:09 PM
3rd - Detroit Locker 4.10, 2" Rovertym Springs, Bodylift - Parting out Mudrover mudrover For Sale - Parts 6 July 18th, 2004 03:38 PM
