4.0 Temp sensor Size - Defender Source
Old December 29th, 2010, 05:58 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Has anyone swapped out the temp sensor in the 4.0? I ordered the m-16 and m-14 from egauges and both are too big.
Because it was raining out, i went ahead and put in the new gauge. At temp I am showing around 185 with the old sending unit and the new gauge.
If anyone has done the swap, I part number would be awesome, but I am thinking that I am close enough on the OEM sending unit to make this work.
Thoughts?
Old December 30th, 2010, 11:26 PM
97-D90-736
Nick Vogel
BTT
Does someone know what the water temp is when the engine is completely warmed up?
Old December 31st, 2010, 12:26 AM
2yellowlabs's Avatar
2yellowlabs
Rob
92 RRC, 99 DII, 06 LR3, 09 LR2
180 degrees
Thank you -
Rob
sensor
Megasquirt with 4.0 dnewman9 Defender Technical Discussions 7 December 14th, 2005 09:44 AM
water temp stabilizer switch david jenson Defender Technical Discussions 1 June 16th, 2004 08:50 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
4.0 short blocks $1200 shipped evilfij For Sale - Parts 2 November 7th, 2003 10:57 PM
