4.0 internals same as 4.6? - Defender Source
Old January 17th, 2007, 03:02 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I know this has been discussed before but I'd like to clarify just to be sure because I've seen some conflicting information regarding the swaping of these parts. So far this is what I got..........there is no difference between a 4.0 & 4.6 block other than the crank? Meaning the bore size, pistons and rods are the same, but only the crank has a different stroke? I'd like to know because I have a good used 4.0 block and is considereing purchasing the crank/rods/pistons from a 4.6. Obviously if the rods and pistons are the same, I'd like to keep the ones I already have from the 4.0. Again any help is appreciated, Cheers!
Neil
Old January 17th, 2007, 03:08 PM
pendy's Avatar
pendy
jim pendleton
89'd90
There are different part numbers for the pistons.
JP
legend in my own mind
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The block is the same, the crank, rods and pistons are different. I seriously considered using the 4.6 crank with the 4.0 rods and pistons but the compression ratio would be about 11:1 or so if memory serves and that is just too high for my tastes--especially if you have to borrow gas from someone on the trail. You will need to get the 4.6 crank/rod/pistons to use it and keep the 9.*:1 compression (9.3?).
Good luck with your conversion.
Old January 17th, 2007, 03:26 PM
Neil McCauley
Neil McCauley
Thanks, I guess that settles it, I'm going to Land Rovers Land in Sunland and buy a good used 4.6 crank, rods and pistons with a set of new mains, rods and rings to put in my used 4.0 block. Hope it comes out alright (projects like these are nail biters)
Neil
Old January 17th, 2007, 03:53 PM
" I seriously considered using the 4.6 crank with the 4.0 rods and pistons but the compression ratio would be about 11:1 or so if memory serves and that is just too high for my tastes--"
Humm . . . . . 11:1 really? I think you could get down a bit with using 3.9 heads with the composite gaskets.
Ron
4.0 to 4.6 parts? gtg067i Defender Technical Discussions 6 September 11th, 2010 08:40 AM
3.9 to 4.6 1995 D-90 boxerhips Defender Technical Discussions 5 January 25th, 2006 07:20 PM
service history?buying a range rover 4.0 or 4.6 mattdh Misc. Chit-Chat 2 December 20th, 2004 08:59 PM
Replacing 4.0 with 4.6 Trevor Tarr Defender Technical Discussions 17 December 15th, 2004 10:21 PM
General consensus question 4.0 or 4.6 to replace 3.5 draaronr Defender Technical Discussions 18 August 19th, 2004 05:25 PM
