4.0 Intermittent Sputter/Stall - Defender Source
Old May 7th, 2013, 12:26 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
96 Disco with the 4.0. Every once in a while when I start it up it has a high idle (1500rpms), and eventually smooths out to normal once it warms up. But the main issue is that it will intermittently sputter and stall at idle, usually when the motor is warm. The CEL has not come on. I've checked for vacuum leaks, checked all hoses, replaced the MAF, cleaned the intake, verified spark to all 8 cylinders, 02s read fine on the code reader. Zero hard starts, or issues restarting. I have not checked fuel pressure as I don't think it's a pump/filter issue.
As the issue is intermittent, I've concluded it's electronic related. Thoughts?
Semper Fi!
Old May 7th, 2013, 12:54 PM
Check the wiring for the crank sensor, it will rub through on the block and cause an intermittent misfire.
Old May 7th, 2013, 01:00 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
I'm thinking MAF but you said you replaced that...do you have another?
Old May 7th, 2013, 01:38 PM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
Open the ecu up and check for corrosion on the boards.
Old May 7th, 2013, 04:25 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I have a very similar issue on my 95 Disco. When the truck is at temperature and I come to a stop it might sputter once in a while, but has never stalled. No light come on and it acts normal after that. I was thinking it was fuel related. Maybe fuel temp or filter could be clogged. I've never looked into it too deep but its very simliar symptoms.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
4.0, auto tranny, axles for sale Method PHX For Sale - Parts 0 February 8th, 2006 06:39 PM
Megasquirt with 4.0 dnewman9 Defender Technical Discussions 7 December 14th, 2005 09:44 AM
Is Supercharging the 4.0 Dangerous? gtg067i Defender Technical Discussions 14 March 11th, 2005 07:18 PM
4.0 engines going cheap KeithD Defender Technical Discussions 0 December 17th, 2003 11:44 AM
4.0 short blocks $1200 shipped evilfij For Sale - Parts 2 November 7th, 2003 10:57 PM
