4.0 heater pipe - Defender Source
Old May 28th, 2005, 04:10 PM
Question 4.0 heater pipe
OK there are 2 hoses coming out of the heater, on a 4.0 (1997) one goes to the manifold at the front of the engine, the other stays next to the other then it connects to a pipe and drops down behind the alternator, then what does it connect to? Does it T into the lower Radiator hose? Does it ride off into the sunset on horseback?
Thanks!
Old May 28th, 2005, 05:08 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
It goes to the water pump.
Old May 29th, 2005, 09:51 AM
I must be missing something I can't see where it connects to the water pump. Note I don't have a V-belt water pump, I have the newer serp belt water pump like in these pictures.
http://www.northeastbritishparts.com...20LAND%20ROVER
http://www.roverconnection.com/Parts/waterpump.htm
http://www.roverparts.com/ProductLis...umber=STC4378G
Old May 29th, 2005, 10:35 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Goes to the lower rad hose! Another great Brit Engineering feet!
Old May 29th, 2005, 12:45 PM
Hmm, so I need to T into it then, that should be fun finding something to do that.
Old May 29th, 2005, 12:55 PM
I have two radiator hoses for the Tdi - both OEM (I got an extra to have a spare). One has the heater hose molded into the larger hose, the other has a couple plastic T sections and shorter lenghts of hose - so that suggest to me that there is no issue at all with using a hard T in your application. I would just suggest using a couple lengths of stainless tubing that your hoses will fit around, take about 4 inches of the fatter tube, and have someone weld about 1.5 inches of the shorter tube in the middle. Either put a bead around the ends, or just double clamp it.
Old May 29th, 2005, 12:59 PM
Thats about what I was thinking, I was going to head over to Home Depot to see what I could rig up.
Thanks Peter and Jim!
Old May 29th, 2005, 02:47 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Sorry about that--I have a 94/v-belt set up. It sounds like you are getting it solved.
Old May 29th, 2005, 07:37 PM
Its cool Chris. I did a temp fix using PVC pipe so that I could try and start it, but I think the injectors are not firing so I have some wiring to trace out in the morning.
heater
Heater Pipe Filler Tower Grover Defender Technical Discussions 2 November 14th, 2006 12:31 PM
Megasquirt with 4.0 dnewman9 Defender Technical Discussions 7 December 14th, 2005 09:44 AM
Custom exhust setup? Pipe size to use?? Defender50th Defender Technical Discussions 8 November 22nd, 2005 12:21 PM
heater motor lubricant ??? artm Defender Technical Discussions 1 October 18th, 2003 04:42 PM
