4.0 fuel injectors - Defender Source
Old January 17th, 2009, 03:51 PM
crobinson
Chris Robinson
97' D1
4.0 fuel injectors
I'm getting a flashing check engine light 97' D90. Done a presure test at the fuel rail.
Key on not running 38psi
Running 30-31psi
stopped key off 34 psi
Did not remove presure tester, key off, one hour later 8psi
Is this normal or do I have a leaking injector?
I have been getting misfire and cat damage codes but engine runs smooth.
Old January 17th, 2009, 07:08 PM
imola's Avatar
imola
is the truck hard to start when cold?
Old January 17th, 2009, 07:23 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Definitely a leaking injector somewhere, it should hold pressure for days.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 17th, 2009, 09:08 PM
crobinson
Chris Robinson
97' D1
Starts fine when cold. But on some days the check light will flash when I first start off and then stop after a min or so.
fuel
