4.0 Engine issues? - Defender Source
Old September 22nd, 2016, 07:48 AM
terryjm1's Avatar
terryjm1
Terry
1988 Land Rover Santana & 98 D1 TDI
4.0 Engine issues?
I am considering buying a D1 with a 4.0 that has 80,000 miles on the engine. They seem to have been well cared for maintained miles. Sorry, I know this is a Defender discussion section but I know many of you drive Defenders with 4.0 engines and many of you also have or have had a D1.
I have some experience with the 4.0 engine and it seems head gaskets are a common problem. It seems most of the higher mileage ones get the head gaskets done at about 100,000 miles. My question is this simply when they fail or is it caused mostly by issues like overheating?
Is it good preventive maintenance to R&r them at 100,000 to avoid damaging the rest of the engine when the coolant gets in the crankcase or perhaps could damage the catalytic converters and O2 sensors?
I am planning to drive it on a 2500 mile road trip with about 400 through high elevation mountain passes pulling a trailer. Is this too ambitious for an 80K truck. I will need to make this trip 10 to 15 times over the next few years. Am I asking to be stranded with an engine that has lost a head gasket?
Kind regards,
Terry
Old September 22nd, 2016, 08:02 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Over heating is the killer. If the engine over heats you run the chance of slipping a liner and toasting the engine. Make sure the cooling system is up to the task. Do not rely on the gauge.
Land Rover 110
Old September 22nd, 2016, 09:44 AM
Ray_G's Avatar
Ray_G
Ray Gerber
So now on my third D1 I'd say that the overheating alluded to, and to a certain degree specifically the HG, are problematic-but not nearly as much as they are with a Dii. Could you do the HG as a preventative? Sure, I guess. Would I-on an 80k mile truck? No. I'd change all the fluids, make sure the radiator was good to go, the coolant tank isn't part of the prone to crack generation and drive the truck.
That said, it is worth noting that depending on budget you may find an LR3 (aka D3) far more suitable for consistent, protracted, towing and with their prices these days depending on your budget worth considering.
Food for thought.
r-
Ray
Old September 22nd, 2016, 09:53 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I have 150-160k-ish on 2 different 4.0GEMS. One NAS90 the other is my kid's 97D1. Neither have had their HG's done but I keep a close eye on temps and coolant levels. I now use an IR gun to check temps as well. I figure if the temps are safe and the coolant is steady you're good. Even good gaskets will blow if the cooling system is not constantly in check.
Old September 22nd, 2016, 09:57 AM
My brother has a 96 p38 with 300k on it. Head gaskets have never been done, radiator never been replaced, although he did come pilfer a new water pump off my shelf last month.
Old September 22nd, 2016, 10:09 AM
ezzzzzzz
Mark Garrenton
muthalickin pilferers...whatcha goin do?
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old September 22nd, 2016, 10:20 AM
When I'm missing something, I know he's absconded with it. Such a punk
Old September 22nd, 2016, 12:34 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
97 D1 with 300k.....never touched sans a radiator.....going strong....
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old September 22nd, 2016, 05:05 PM
carlosz's Avatar
carlosz
Carlos
the block will drop a liner before head gasket failure. normally the failed component is valley pan gasket.
the dealer started this fashion of failed head gaskets and due to internet, the cool kids decided to start recommending said repair when not needed.
quite often head gasket failure is misdiagnosed.
keep an eye on your cooling system and don't skimp on maintenance you will be fine.
the truck ran like a "raped ape"
A fussy warm weather creature...
engine
New Owner / Engine Issues scolvus.x Defender Technical Discussions 4 November 27th, 2012 09:45 PM
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
Lifter / engine tapping... oil pressure issues.. revtor Defender Technical Discussions 10 July 12th, 2007 11:04 PM
Engine Temp issues sflash868 Defender Technical Discussions 11 May 25th, 2005 04:51 PM
