4.0/4.6L Oil Cooler Line Time Cover Adapter - Defender Source
Old November 9th, 2010, 07:58 AM
The Dro
Dro
1988 Ninety
I'm about to upgrade my oil cooler lines and found that there are only a couple of companies out there that make a kit for the 4.0/4.6L engines. These motors do not have a sandwich adapter and need a custom setup. The inlet and outlet are cast into the timing cover.
How can you make sure that the adapter hole aligns with the timing cover opening?
On the stuck oil cooler line, the adapter hole is fixed to the hose assembly and will mate without a problem. You are not turning the hose, just a nut.
On these, the hole will turn as you tighten the adapter and can end up miss aligned and damage your pump.
Am I wrong with this? Has anyone tried these kits?
Thanks!!!
Old November 9th, 2010, 08:30 AM
Just delete the oil cooler and be done.
Old November 9th, 2010, 11:17 AM
The Dro
Dro
1988 Ninety
Funny thing... you're not the first person that tells me this.
again... being paranoid... I don't like the idea... Rover motors like to run hotter than others.
cover
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
oil cooler line flow direction andyrad Defender Technical Discussions 5 January 23rd, 2007 11:49 PM
replacement oil cooler lines Tdi artm Defender Technical Discussions 3 August 14th, 2006 06:34 PM
newish oil cooler hoses milli Defender Technical Discussions 0 February 24th, 2006 12:13 PM
oil cooler lines CHRIS C Defender Technical Discussions 39 December 21st, 2004 11:30 PM
