3link center link - castor adjustment - Defender Source
Old July 14th, 2005, 09:59 PM
Jase
Jase
pending
I'm adjusting the castor on my 3-link to compensate for an addition inch of lift and was curious if anyone knew approximately how many degrees are gained by turning the center link one complete turn out? One turn doesn't look like much.
Thanks in advance to anyone who has measured the adjustment. I'm hoping to avoid trial and trial and trail.
Old July 15th, 2005, 10:32 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jason, do you have it set up to the stock angle right now? Do you have the stock drive shaft or a double cardon unit?
Legend in My Own Mind.
Old July 15th, 2005, 12:09 PM
Jase
Jase
pending
My best guess is that the angle was stock. I took the center link out and turned it 1.5 turns. Road feel is good. The floating feeling I got with the additional one inch is gone.
I have a DC unit in the front, but I'm moving to a dual DC. The front end is now OME 753s and an Rovertym 1 inch spring seat.
Old July 16th, 2005, 07:28 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jason, I am running 3" sRYM springs up front and only have a single DC front shaft. You do not need a double. I get no vibs at all and I have a stock HD shaft in the rear. I can get you some angles sunday evening if you want. My truck drives and handles very well.
Old July 16th, 2005, 09:24 AM
Jase
Jase
pending
I spent 60 miles on the highway yesterday and I'm vibe free with my single DC. But, I got a great deal on a dual DC so my single DC will become a spare. Similar to your setup, the rear DS is custom but does not have a DC joint.
Don't go out of your way, but next time you're working on the truck please take some angles. It would be great to know what is working for you. Again, I'm in good shape and don't need to know the angles ASAP but it would be good info to have.
Thank you
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
SG 3-link- center link bushing at the cross member Noah Defender Technical Discussions 2 October 14th, 2006 10:25 AM
center link redrover Misc. Chit-Chat 6 August 16th, 2006 12:12 AM
Fusable Link by batt on 92 RRC...? RedRhinoProducts Defender Technical Discussions 5 February 6th, 2005 07:23 PM
